Tip & How-To about Computers & Internet
Installing Windows XP
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Every one who owns a computer should maintain it on their own from time to time.
Reinstalling your Operating System is one of the methods of computer maintenance, and is a bit complex.
With these steps, you will successfully install Windows XP into your computer.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
Computers & Internet Logo
0XE0EF005D
The issue can be caused by the damaged system files or hardware device.
I suggest trying the following method to troubleshoot the issue:
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Please continue with the following instructions if the above suggestion does not help:
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ..." appears.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. (Click the operating system that you want to repair), and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type "chkdsk /F C:" (without quotation marks) and click Enter.
8. Restart the computer and have a test.
If the issue still exits, please move to the below steps:
In-place Upgrade Installation
Technically, you won't lose any data to take an In-place Upgrade Installation. In order to avoid any unexpected problem, I suggest you backup your data before taking In-place Upgrade Installation.
1. Start the computer by using the current Operating System.
2. Insert the Windows Vista DVD in the computer's DVD drive.
3. Use one of the following procedures, as appropriate:
• If Windows automatically detects the DVD, the Install now screen appears.
Click Install now.
• If Windows does not automatically detect the DVD, follow these steps:
a. Click Start, type (Drive: )\setup.exe in the Start Search box, and then clickEnter.
Note: (Drive: ) is the drive letter of the computer's DVD drive.
b. Click Install now.
4. When you reach the "Which type of installation do you want?" screen, click Upgrade to upgrade the current operating system to Windows Vista.
Installing and reinstalling Windows
If both of the above two methods do not work on your issue, please contact the manufacturer to check the hardware.
Regards,
Thulasiramki.
Feb 14, 2014 | Computers & Internet
all step to format pc
insert the operating system CD, restart the computer and enter BIOS, change boot method to CD or DVD drive first, save changes, restart and then let it boot to the OS CD, select the option to install OS then you can delete partitions or just reformat existing partitions before reinstalling the OS. Be sure to save important files before you start with the process. hope it helps
Mar 14, 2011 | Computers & Internet
reinstalling system disc. Manual option to select Windows System Restore but computer only allows a choice between completely restore system to factory defaults or restore operating systems and retain user data. Which should I choose.
depends if you want the all data you have put on the computer or you just want to start all over and set it up again with your own personal data back in
hope this helps you make a choice
Jan 24, 2011 | Computers & Internet
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
Sep 08, 2009 | VIA P4X266 PE11-L Motherboard
PROBLEM SIGNING IN YAHOO MESSENGER
uninstall yahoo messenger from your computer
restart computer.
defrag drive,
delete temp files in temp folder:
start>run>%temp%...delete
start>run>temp...delete
start>run>prefetch...dlete
now try reinstalling YM. download the installer from majorgeeks.com
dont do the online install. this will work now
Mar 25, 2008 | Yahoo YHT-630 System
121 people viewed this tip
David Payne
David Payne
