Tip & How-To about Computers & Internet
Quick way to install many useful programs
We use a very useful program in our computer shop to quickly install many useful applications with just one click. The program is called Ninite and can be found at: ninite.com Its very easy to use too. You go to the web site and check the apps that you want to install from the list. Next you click the button that says "get Installer", this saves the installer to the location of your choice. Now you can just run the installer on the computer you need the apps installed on while the PC is connected to the internet. The Ninite installer will check the version of Windows you are running and download the proper version of the apps and install them without any additional input from you. The newest version of each app will be installed and configured to your system while you just sit back and watch. This is a great program you install certain programs on all of your machines, now you can do it much faster.
I hope this makes your PC installs easier too.
Buddy
Corporate Computer
www.ccl-la.com
Computers & Internet Logo
I am workig on win xp sp3.What is the problem is,in the system tools there is no disk cleanup option.My system became slow. So how can I find it now?How can I make my system work fast?
First go to https://www.Piriform.com and download the free version of CCleaner. Install it and run it. However you must first go through their list of cookies and protect the ones that you want saved. You'll have to do that for about a week.
Then go to the following site: https://ninite.com. Use it to download Malwarebytes Anti-Malware (the free version)and run it and. SUPERAntispyware (the free version), but be sure to click on only one of them before you click on the big green rectangle. Then don't install it, but uncheck the first one, check the second one and click on the big green rectangle. You will now have two files that look like this: Ninite "the program name).exe. Then double-click on one of them and let it run, thus installing the program while Ninite makes sure that no malware is installed. Then do the same for the other. Then run these programs. These will help you check to see if you have an infection of malware of any type. Next go to https://www.bleepingcomputer, download Rkill and jrt. When you try to download jrt you will be given a choice of using the Bleeping computer site or the "authors site". It doesn't matter which of them you use. Note: these program do not need to be installed - just run them. First run Rkill. Then run jrt which function at the DOS level. This is a slow program but an extremely efficient one. jrt stands for Junkware Removal Tool.
Next go back to Ninite and download Glary and have Ninite install it for you. Don't let them touch your registry, but have them clean your Hard Drive.
That should do it for you. Note - keep the Ninite installation files in their own folder. Ninite knows when an update occurs and if once a week you double-click on each of them it will install the update safely or tell you that you still have the current file.
Thought, XP Pro is now unsupported. There is probably an XP Pro forum on the Internet where you can ask questions. Still I would seriously consider updating to Windows 7 (if possible).
Dec 16, 2014 | Computers & Internet
NMP-570w audio but no video
TRY A DIFFERENT VIDEO PLAYER LIKE VIDEO LAN PLAYER OR KMPLAYER. YOU CAN GET THESE INSTALLED ON YOU COMPUTER AT WWW.NINITE.COM CHOOSE THE PLAYER OR PLAYERS AND THEN CLICK GET INSTALLER. THEN IT WILL INSTALL THE PROGRAM OR PROGRAMS FOR YOU. THEN TRY YOUR VIDEO. GOOD LUCK.
Ninite Install or Update Multiple Apps at Once
Nov 24, 2014 | ViewSonic NMP-570W - Multimedia NMP-570W...
Why are all browsers having a problem?
CLEAN UP YOUR MACHINE. Would be one suggestion. try running some of these programs below or take it into a shop to have it serviced. Good luck.
Suggest Glary under Utilities. Once you select it then click install. Once installed the run it. Good luck.
Another great utility is called CCLEANER Check out the link below. Good Luck.
CCleaner
Jul 02, 2014 | Facebook Social Network
i have been trying to install adobe flash player on my hp pavillion for safari yet when i try to get it to download it says i have to close safari how is it that i must install it then??
Adobe Flash Player will only install when Safari is not running. This is normal. Adobe Flash Player uses a separate installer that will install Flash independently.
Get the flash player at this web site:
http://get.adobe.com/flashplayer/
I hope you find this information helpful.
Mar 03, 2011 | Adobe Computers & Internet
it gives error in windows 7 during gameplay. something like "there is not much space" . what can i do?
you should download a disk cleaner program to clear out drive space. I recommend ccleaner it is quick and easy to use.
here is a direct link to it: www.ninite.com/ccleaner/
just click save and run and it will install it for you automatically.
Mar 02, 2011 | Atari Backyard Basketball 2007 for Windows
267 people viewed this tip
David Payne
David Payne
