Tip & How-To about Microsoft Windows Vista Ultimate Edition
Increase the speed of statrt menu button
This tip is for the increase speed of start & menu bbutton .It's so simple the steps are as fallow's
1) Press statr button.
2)Go Run & write "regedit".
3)HKEY_CURRENT USER & then control panel
4)Double click on "Desktop".
5)Double click on "Menu show delay".
6)change it's value from 400 to 0 then press ok.
7)Restart u'r computer. Go on start panel see the magic
Microsoft Windows Vista Ultimate Edition Logo
increase internet speed
Hi,do the following step by step instructions to increase your Internet Speed:
Step 1 : First of all Click on start button.
Step 2 : Select the run button from the start menu or type Run and click on it.
Step 3 : Type gpedit.msc
Step 4 : Expand the Administrative Templates branch
Step 5 : Now expand the Network branch
Step 6 : Click on the Qos packet scheduler
Step 7 : Double click Limit reservable bandwidth
Step 8 : Check the enabled
Step 9 : Change bandwidth Limit to 0 %
Step 10: Click the Apply button and OK.
Step 11: Now restart your PC.
Step 12. check if its now better.
Before and after doing these steps check your internet uploading and downloading speed results in both MBps and Mbps units from Scanmyspeed.com .
Dec 23, 2013 | TP-LINK Computers & Internet
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if it recognizes my request but will not run. I tried to reset but the 6000 stays in the display.
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
My PS2 slim console takes forever to load between game scenes, Is there something I can do to speed up the game?
Dear Sir!You should increase the disc speed.Follow these steps to increase the disc speed:
Step 1>>Turn on your PS2 without inserting any disc into it. Step 2>>Wait for the main menu [Containing Browser and System Configuration ]. Step 3>>Press Triangle Button to enter Version Information menu. Step 4>>Move the cursor to Play Station Driver and Press Triangle to enter Play Station Driver menu. Step 5>>At PlayStation Driver screen, Press x at Disc Speed and set it to Fast. Step 6>>Enter game disc and enjoy.
Hope that solves your problem.Good Luck!
Jan 10, 2010 | Sony PlayStation 2 (PS2) Console
293 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
