Tip & How-To about Apple iPhone Smartphone
How to reset/restart Apple Iphone?
You can perform this reset,whenever there is a software issue with I phone
To restart I Phone, first you need to turn it off by pressing and holding the Sleep button,Release it when a red slider appears.
You have to slide your finger on screen.After few seconds I Phone will turn off
After this turn i Phone ON by pressing and holding the Sleep button until the Apple logo appears.
How to Reset an iPod shuffle and troubleshoot
Apple iPhone Smartphone Logo
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
my HTC_HD2 when i turn on it wont get through. . the display is always htc logo. . what should i do?
This looks like the OS , software has got corrupted on your phone . You will need to hard reset the Phone . Hoping that you are running default Windows mobile 6.5 here is how you can do it .
thumps up for me if it works . Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
Aug 04, 2011 | HTC HD2 Smartphone
My HTC tatto phone has become very erratic. After every 1 second of making a call the power end menu options come up on the screen. The phone wont hang up after having pressed the "End Call" button. If I select the Power Off button, the phone restarts on its own (like restart in a computer). When I am getting an incoming call, the line will automatically get disconnected and show a missed call alert. Most annoying is that when I am talking on a call, the phone simply restarts on its own. PLEASE HELP! I JUST bought this phone 8 months back . Do I need to change it now?
First, try a factory reset and see if that resolves your problem. I'm afraid that will wipe all the data on the phone, but you will have to do that anyway if you want to solve this problem.
Here are the instructions for the factory reset:
Performing a factory reset via settings
The most convenient way to do a factory reset is via the phone settings.
  1. Press HOME > MENU, and then tap Settings > SD card & phone storage > Factory data reset.
  2. On the Factory data reset screen, tap Reset phone, and then tap Erase everything. Your phone will erase all personal data and restart. It may take a few minutes for the process to complete.
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the phone buttons.
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button.
  2. Press the ENTER button to begin the reset process. (Otherwise, press the END CALL/POWER button to cancel.)
Aug 06, 2010 | HTC Tattoo Cell Phone
how do i perform a hard reset of my htc710s
Preliminary instructions:
A hard reset(Factory reset) will wipe out every piece of data you have on your phone including the data on your sim , memory card and your phone's software.So remove your sim and memory cards before you begin the reset.
You must re-install your phone's software after the reset so make sure that you have the software handy.
Procedure:
Press and hold the softkeys on your phone for 3 seconds, press the powerbutton then follown onscreen instructions. Your phone will turn off and restarts after a while(5-10 min depending on any additional software you have installed) as it erases the data during the restart.
Good luck,
Sai.
Nov 28, 2009 | HTC S710 Smartphone
819 people viewed this tip
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
