Tip & How-To about Computers & Internet
How to Remove Windows XP's Messenger
Theoretically, you can get rid of it (as well as a few other things). Windows 2000 power users should already be familiar with this tweak.
Fire up the Windows Explorer and navigate your way to the %SYSTEMROOT% \ INF folder. What the heck is that thingy with the percentage signs? It's a variable. For most people, %SYSTEMROOT% is C:\Windows. For others, it may be E:\WinXP. Get it? Okay, on with the hack! In the INF folder, open sysoc.inf (but not before making a BACKUP copy first). Before your eyes glaze over, look for the line containing "msmsgs" in it. Near the end of that particular line, you'll notice that the word "hide" is not so hidden. Go ahead and delete "hide" (so that the flanking commas are left sitting next to one another). Save the file and close it. Now, open the Add and Remove Programs applet in the Control Panel. Click the Add / Remove Windows Components icon. You should see "Windows Messenger" in that list. Remove the checkmark from its box, and you should be set. NOTE: there are other hidden system components in that sysoc.inf file, too. Remove "hide" and the subsequent programs at your own risk.
Computers & Internet Logo
Tried it today and none of the windows work from master switch on drivers side except ft passenger window, which went down but will not go back up.
You can't put up the front passenger window with it's own switch ? Did you check the POWER WINDOW RELAY in the instrument panel fuse / relay box ? An you checked POWER fuse 30amp same fuse box ? All window switches have direct power from power window relay !
Fuse Block - Instrument Panel
Left of the Steering Column, behind the storage Compartment
P/W Relay
Sunroof Switch Assembly, Window Switch - Left Front, Window Switch - Left Rear, Window Switch - Right Front, Window Switch - Right Rear
Apr 02, 2015 | 2003 Pontiac Vibe
how do you reset your user name and password if you have forgotton it and cant get in to change it
Theoretically you can't. Depending on what you need you can try this:
If you have lost windows password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program from in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Or contact Toshiba.com for advice.
Dec 22, 2010 | Toshiba Computers & Internet
259 people viewed this tip
David Payne
David Payne
