Tip & How-To about Sony PlayStation Portable (PSP) Console
Psp tips on: backround colour, file images, car stereo system.
The PSP is the hottest little handheld around right now. The PlayStation Portable Handheld system is very impressive and plays great games, music and movies. Additionally, the system does have a few tricks as well. Here are a couple of things you can try, some are fairly simple. Please note you must be careful with some of these tricks and they will be marked by a * before the “how to” area. Due to the price and the sensitive LCD screen always use caution when trying anything below.
Jam to Tunes Using Your Car Stereo System Speakers * Use the following instructions to play your PSP games and movies with your cars audio system. You will need a FM modulator, a cable with a male stereo 1/8" headphone connector at one end and split left and right RCA connectors at the other. The red wire with the 'in' line fuse goes to your car battery or switch. The ground wire grounds to the frame. Set the car's CD or tape deck to the FM frequency that is on the modulator. The frequency is usually 88.7 or 89.1. Plug the RCA connectors from the cable into the RCA jacks on the modulator. Plug the headphone end of the cable into the PSP. Turn on the PSP with the volume set at half way.
The PSP's sound goes through your car's antenna. No extra wires are needed nor are any other adjustments. Your games, music and movies will now play through your car's stereo speakers. Please note: take care when trying this and make sure you know how to use the modulator and know the right way to hook up the wire to the fuse box and ground wire. If this is not done right, this can damage or even short out the PSP. This one is for parents!
Changing the Save File Images * Whenever you save a game, one or two pictures are created on your memory stick: ICON#.PNG - the 144x80 icon displayed when you select your saved file. The #, normally 0, may be higher if a game places multiple saves in one folder. PIC 1. PNG - the 480x272 background that's displayed when you cursor over your save or game disk. Knowing this, you can customize your save icons and backgrounds by simply replacing them with new . PNG files. However, make sure that you keep the new file less than or equal to the original file's resolution, or the PSP will cut off sections to make it fit.
First Connect your PSP to your PC. Then locate the save file you want to change. All saves are located in the PSPSAVEDATA folder, divided into separate sub folders to keep necessary files together. Once you've found the save icon you want to change, add .ori to the end of the file name, in case you ever want to change it back to the original. Resize the image you want as you're save icon to 144x80 and save it as a .PNG named ICON#.PNG - “where # was the number found on the file you renamed”. Then move the new picture into your save folder.
Now, whenever you see your save files on your PSP, its icon will be the picture you changed it to. Use the same method to change PIC 1.PNG files to your own custom pictures, but remember that the resolutions must be at most 480x272. *Please note this is a bit complicated and could result in losing all saves if not done correctly. This tweak is really for those who have knowledge of using these types of files. Please use caution when attempting this or have someone that knows how to work with these files help you.
Choosing a Background Color and Keeping it the Same The PSP will change colors of the background screen every month automatically. You can pick a color that you like and have it stay that way. Simply go into the settings and select the month that has that color, when it changes, reselect the month. Note: Your date will always be wrong, but if color and style is your concern, this simple tweak does the trick.
Sony PlayStation Portable (PSP) Console Logo
WHAT IS A PSP
A PSP is a handheld gaming system made by sony. For more information please check out this link and just scroll down the page a bit:
http://us.playstation.com/psp/
Oct 10, 2010 | Sony PlayStation Portable (PSP) Console
The umd would not play 4 some reason i dont know why
neither do i
UMD? what are you talking about
this ? The Universal Media Disc (UMD) is an optical disc medium developed by Sony for use on the PlayStation Portable. It can hold up to 1.8 gigabytes of data. It is the first optical disc format to be used for a handheld video game system.
google psp repair
Jul 12, 2010 | Computers & Internet
Hi I just downloaded That new baseball game called the Show. It's not working or I don't understand? What is aPSP? can't I just download and play? Can you help?
If the game is marked as compatible with the PSP that means it will only play on a PSP. This is the handheld portable unit that Sony put put a few years ago. The PSP's use small dvd's for their games and programs. They are not compatible with the PS3 system.
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
I need to perform a soft reset on my sony playstation 3. How do I do that?
A soft reset? on Playstation 3? Unplug it?
do you mean PSP playstation portable? the hand console? A simple reset can be done by removing the battery from the handheld console.
Nov 15, 2008 | Sony PlayStation Portable (PSP) Console
717 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
