Tip & How-To about Computers & Internet
Autorun Trick
This is to share you guys a tool that I came across on the internet. This application is called autoruns. If you are thinking that this software will just disable autorun.inf, you are wrong because it can disable almost ever automatically running exe, services, and even dll.
Why use this application?
1. Remove Virus / Malware
- There are viruses that enters in you start-up and you can use this application to disable it. Actually sometimes it is better to disable the virus rather than deleting. When you delete a virus it might come back, but when you disable it, it is still there but it is not running.
2. Small but terrible
- The installer of this software is only 581kb yet it can do so many trick to your PC.
3. Easy to use and Safe
- Autoruns has a user-friendly interface. The configuration take effect immediately after you have unchecked an item yet it can be revert back by just checking it again. ^^
4. Approved by Microsoft
- As a matter of fact, Microsoft posted this application. So I believe they have tried it already and also amazed by the power of this software. ^^
5. Powerful
-The application let you edit your registry without browsing your registry all the time. You can double click the item that you want to edit and viola! you will be redirected to the registry of the item you select.
6. Best of all Speed-up your computer!
- You can disable some application that you don't really need to start when you open your computer. This will not just speed up your start-up but will also save up memory and cpu usage for faster processing. Not everything can be changed in the msconfig but with Autoruns, YOU CAN! ^^
This is a must try application that might help you in every way. ^^
Hope this help you with your problem.
Download Autoruns here.
Computers & Internet Logo
How do I add presenters and share the screen during a hangout?
ezTalks Cloud Meeting is a powerful video conferencing and screen sharing software packed with features. One of the features included with its free version is screen sharing. This software is ideal for meetings that require interaction and collaboration among its participants. It offers its users the ability to share their computer screens with their selected participants. There are added features that make this software extremely useful such as the whiteboard tool that can be used for sketching during a live presentation. ezTalks Free online meeting via desktop and mobile users can maximize the use of this software without any problem. Convenience and efficiency seem to be the keywords that can be associated with this screen sharing software. It gives its users full control with its options for muting and unmuting of conference participants, recording meetings hosted through the software, and controlling the audio and video.
May 22, 2014 | Google+ Hangouts
says it cant find a shared pc why i have wireless internet
Ok look. Samsung has a software to share PC (desktop or laptop) media with your TV. Download the application from Samsung website. The application is called "Samsung PC Share Manager".
You need to learn how to use that software.
Good Luck. Remember to rate my answer. Please.
Feb 16, 2011 | Televison & Video
worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
Orbicam is in use by another application
Try using an application called SplitCam, which allows you to share the webcam across applications.
http://www.pcauthorities.com/software-reviews/splitcam-share-your-webcam
May 05, 2009 | Computers & Internet
disk not accessible
its probebly because of some virus
you didn't mention that your home network is using internet or not
if yes then probebly you get any vrus from net which is not allowing to see you your disk drive
find any good antivirus and scan your hard drive
dont relay on your exixting anti virus it might not working now
and one more thing to do
whichever drive you can not open try to open it from run
start > run > c:
it shows you c drive in case of c drive 's problem
now find autorun.inf and delet all content from it and save blank autorun.inf
sothat your os will work on its own and not relay on autorun.inf
try this out
Mar 29, 2008 | HP Pavilion dv4000 Notebook
156 people viewed this tip
David Payne
David Payne
