Tip & How-To about Computers & Internet
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
Computers & Internet Logo
When my desk top come up I dont know what icon to click on to get on line
1. Goto Start >> Connect To >> Select Any Connection >> Double-Click to connect internet.
2. Goto Start >> Internet Explorer / Mozilla Firefox >> Type any website address in the Address Bar >> Press Enter.
3. Goto Start >> Programs >> Internet Explorer / Mozilla Firefox.
4. Click on Internet Explorer ('e' symbol) in the Quik Launch Bar (right-side of Start button).
5. Double-Click the Internet Explorer ('e' symbol) on the Desktop.
please rate this advice if it helps....tc! :)
Jan 12, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
I cannot open messages
The new mail requires the latest browsers. Update your browser here...
for Firefox: http://www.mozilla.com/en-US/launch/?utm…
for Internet Explorer here:http://www.microsoft.com/windows/product…
for Netscape here: http://browser.netscape.com/
If you do not wish to upgrade you could try to login from here for faster and error-free access
http://us.m.yahoo.com/p/mail
Use the below link to return to yahoo mail classic and click yes ,when it asks for "opt out"
http://us.mg1.mail.yahoo.com/dc/optout?s
for co.in account,
http://in.mg1.mail.yahoo.com/dc/optout?s
If this was helpful please Vote best Answer. Thanks
Oct 10, 2009 | Yahoo Mail
can't connect to to http address
Try plugging your computer directly into the range extender first, with an ethernet cable. Then check your computer for an IP. To do this follow these steps:
XP: click start> then run> type "cmd" and hit enter.
type "ipconfig" and hit enter, it should show you a default gateway address, that is the number you should type in your browser (IE: internet explorer)
Vista: click start> then in the start search type "cmd" and hit enter.
Type "ipconfig" and hit enter, it should show you a default gateway address, that is the number you should type in your browser (IE: internet explorer)
Jul 12, 2009 | D-Link DI-704P Router
password not working
1. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
Try other browsers like Internet Explorer, Mozilla Firefox, Netscape, etc.
If you still cannot access the routers page, try another computer and connect it on your router. Then repeat the steps.
2. Access the web-based utility of the router.
a. Open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. For security reasons, the router has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
Jul 02, 2009 | NetGear RP614 Router
open messenger ports
Here ya go: To use the configuration utility embedded within your Motorola WiFi Router, you need to connect to it using the HTTP protocol. Launch a web browser (Internet Explorer, Opera, Firefox, or Netscape, etc.) on your computer, type in http://192.168.10.1 (default IP address for its LAN/NIC Interface) in its URL/Location bar, and then press Enter on your keyboard. If presented with a user authentication (login) screen, try the following: Default Motorola Wireless Router Username: admin (lowercase) Default Motorola Wireless Router Password: motorola (lowercase) If you cannot login using the above, it may be so because (a) you are not typing your password correctly, (b) your CAPSLOCK key is on, (c) someone has changed password on your wireless router, and/or (d) the firmware (a set of instructions stored on an EEPROM microchip) encoded within your wireless router is corrupted. Consider resetting your router to its factory default settings if you are stuck.
May 14, 2006 | Arris WR850GP Router
210 people viewed this tip
David Payne
David Payne
