Tip & How-To about Televison & Video
How to Auto Search Your URC or One for All Universal Remote
To program your One For All remote control to operate your TV, the remote has a code searchfunction.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Televison & Video Logo
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
codes and programing
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
I hope that helps.
Dec 22, 2009 | One For All URC-3021 Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
1,595 people viewed this tip
Top Televison & Video Experts
