Tip & How-To about Microwave Ovens
Clean your microwave
Use vinegar and water to clean the inside of your microwave when switched off and use bleach jik to clean the outside body.
Then boil water, whole lemon in the microwave for freshness and store it (the boiled mix after cooled) in the fridge to act for the same.
Microwave Ovens Logo
burning smell motor not working
Unplug the oven and unfasten the cabinet body, using a screwdriver. The body should be attached along the back as well as along the sides or bottom.
Slide the cabinet body back slightly to clear any internal brackets, then lift it off.
Clean the oven, using a vacuum with plastic crevice attachment. Vacuum the fan and other internal parts, then vacuum the vents underneath the oven, on the back and inside the chamber.
Reassemble the oven and plug it in.
Fill a small bowl with a 50-50 mixture of water and white vinegar, then set it in the oven and turn the oven on high for 5 minutes. When the mixture boils, it will remove stubborn smells inside the vents and loosen food particles on the oven walls.
Oct 05, 2011 | Panasonic NN-S963BF Microwave Oven
I have an LG Microwave. A Week back i mistakenly microwaved sausages for 20 min. They got burnt and the microwave also started stinking. i aired it out and microwaved a cup of water twice on separate occasions. I even cleaned the microwave with vinegar. Yet the burning smell hasn't gone. what could be the problem?
Hi hafsahparkak,
Plz follow the steps below once again ...hope it works if not plz revert:
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
    Wipe down the oven walls with a clean sponge.
  • Aug 22, 2011 | Viking DMOC205SS Microwave Oven
    Is this a self cleaning oven? If so how do you set it to self clean?
    Self-cleaning microwave oven?
    Loosen up gunk and grease splattered inside your microwave by following this simple tip. Fill a pyrex measuring cup or other microwave safe bowl with one cup water and put in microwave on high for three minutes. This should bring the water to a boil. Let it set in microwave for several minutes with the door closed.
    Then, wet a sponge or soft rag with a tablespoon of vinegar. If you need a degreaser, add a few drops of dishwashing liquid to it. Wipe microwave clean with the rag or sponge. The microwave will practically clean itself. Now that was easy!
    Jun 03, 2011 | Microwave Ovens
    I have a DeLonghi EAM3200 series expresso machine and I need the instructions for the decalcifying process.
    Typically the process is to simply run a vinegar and water solution through without coffee grounds. Usually a 2 parts vinegar to 1 part water solution will do it. Next, run clean water through 2 or 3 times to rinse out the vinegar. Be sure to let the machine cool between boilings.
    Mar 04, 2011 | DeLonghi Microwave Ovens
    Microwave door has burn spots on the glass of the door...
    The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
    Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
    200 people viewed this tip
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
