Tip & How-To about Computers & Internet
How to hack Windows password on your netbook / laptop using a USB Flash drive
Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0.
Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0 to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen.
In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password.
After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password.
It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
Computers & Internet Logo
how do i reset my windows xp password if i have forgotten it
Forgot Windows XP password? The first thing which you check is whether you forgot windows xp login password or not. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forgot your user account password then try this:
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
Windows XP and further versions also provide another method to recover forgotten Password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. Or try free program called Ophcrack or Windows Password Recovery Tool 3.0.
More detail guide on: http://www.windowspasswordsrecovery.com/bypass-xp-password-in-safe-mode.htm
Dec 01, 2011 | Dell Dimension C521 PC Desktop
Forgot my login password to Windows 7
What if you forgot windows 7 password by accident? How to crack windows 7 password by yourself? Try this
wonderful SmartKey Windows Password Recovery as soon as possible. The same as Windows 8 password recovery tips.
Step 1: Download and install, run the program on a unlocked computer.
Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program.
Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
Sep 08, 2011 | Computers & Internet
i cant get passed the start up password
When you want to login a pc without password or lost password you can consider using Windows Login Recovery, which can help you login directly.
Dec 28, 2010 | Toshiba Satellite A55-S1063 Notebook
how to unlock a dell windows XP home adition laptop when turning on laptop?
Do not worry, we can use dell password recovery tool to complete this task. Windows Password Rescuer is designed for resetting dell Windows 7/vista/XP password. What you should do is prepare a bootable CD/DVD or USB drive and a computer you have access to. Follow four steps help you reset dell windows password without lose anything:
Note: You also can use Windows Password Rescuer to reset Windows 2008/2003/2000 local or domain password easily by these steps on dell computer.
Step 1: Download and install Windows Password Rescuer on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk. You just need to burn it to a blank CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your dell laptop or dell computer, and set the computer boot from the password recovery disk by BIOS setting. If you have trouble in BIOS setting, refer to:
How to set computer boot from CD/DVD.
How to set computer boot from USB drive.
Step 4: After boot from the password recovery disk, Windows Password Rescuer will start up and display a friendly operating window. Then you can reset whichever account password of your dell computer just by a few clicks.
You also can use Windows Password Rescuer to create a new user with administrator privileges for your dell OEM Windows without login. With this new user, you can login your dell computer directly and access control panel to reset other user password.
Jul 11, 2010 | Dell Microsoft Windows XP Home Edition
2,428 people viewed this tip
David Payne
David Payne
