Tip & How-To about Computers & Internet
CMD Prompt here, add to folder context menu windows xp
Add the open cmd prompt to folder context menus also drives and MY Computer
Copy what's in the code area to notepad and save as cmd here. reg
CODE
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Drive\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Drive\shell\cmd\command]
@="cmd.exe /k \"cd %L\ ""
[HKEY_CLASSES_ROOT\Directory\Shell\cmd]
@="Command Prompt"
[HKEY_CLASSES_ROOT\Directory\Shell\cmd\command]
@= "cmd.exe /k \ "cd %L\ ""
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd]
@="Command Prompt"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\cmd\command]
@="cmd.exe /k \"cd %L""
Computers & Internet Logo
I got a code purple trying to restore my computer to its factory settings and now when my computer tries to boot up normally I can't log in using my old password or username and the only way I hav
With the code purple error on the screen, press the shift+f10 to open the cmd prompt.
Whe the cmd prompt opens, type the following command without the quotes "notepad C:\hp\bin\checkdmi\checkdmi.cmd", then after the REM lines add the following code without the quotes "goto cleanup". Save the file and exit notepad and restart your computer by typing the following command without the quotes, "shutdown -r -t 0".
This will cause the checkdmi function in an HP computer to bypass the tattoo check.
Hope this helps
Apr 04, 2012 | HEWLETT-PACKARD Computers & Internet
how to open multiple yahoo messenger in single PC?
Open notepad and copy paste this code :
REGEDIT4
[HKEY_CURRENT_USER\Software\yahoo\pager\Test]
"Plural"=dword:00000001
and go to file ...Save As ..save as type(all files ) ,in file name type install.reg and click save
Next double-click install.reg .
Feb 23, 2011 | Yahoo Messenger
missing taskbar and start menu
Probably your infected. to fix the problem u can visit kelly's korner and copy all the text and then go to notepad and paste the text and then save it as "taskbar.reg" and then after saving it run it. it will prompt you if u want to add the registry information and you say yes. see if that fix's the problem. if u dont know how to open notepad without the startmenu u can try pressing windows key+r and type "notepad" and press ok. remember to save it as a .reg file.
Nov 26, 2008 | Microsoft Windows XP Professional
268 people viewed this tip
David Payne
David Payne
