Tip & How-To about Computers & Internet
How to use your IPOD as an External Drive (Mac)
If you're running out of external Hard drives or don't have a Flash drive on hand, and you need to transfer file or simply trying to copy anything externally, don't worry! Ipod can be a useful tools beside from its original purpose, as being a wonderful portable media device, this digital wonder can practically be used a portable external drive, on which you can store files, JUST like an external HDD (Hard Disk Drive) connected to your Mac.
An example of Ipod classic packs a lot of data storage in just a small package, from 5GB up to 160 GB, and in the future, some Ipod will have more capacity (A Gigabytes is a unit of computer memory of data storage capacity, that is equal to 1,024 megabyte, so One Gigabytes is equal to one billion bytes).
To configure an Ipod to be used an an external Hard Drive please follow this steps:
  1. Of course connect your Ipod to your Mac ( Once this is connected iTunes will automatically launch and connects to the Ipod
  2. Select the Ipod on the source list
  3. Click the summary tab, if its isn't selected already
  4. Select the Enable disk use disk box, (at this time you will see a warning prompt that will explain this procedure, because the Ipod will be acting as Hard Drive (Hard Drive is an optical or magnetic disk that is used to read and write information on it)
  5. Click Ok at the prompt
  6. Click Apply, then it is ready to use.
  7. Note: You must manually eject this before disconnecting the device from your computer after you finished!
Computers & Internet Logo
I want to back up my hard drive to an external hard drive(Western my book 320G)I do not wish to purchase their auto back-up program.Can this be accomplished?
Yes it can,. Your external HDD will show up in "my Computer" as another drive. You can transfer files simply using copy and paste. (or edit -> copy files to folder) which I advise. Bear in mind that hidden, and read only files will not be copied. These files include the mailboxes in Outlook Express. So be careful. I advise making copies of all files of this kind, first.
Mar 16, 2010 | Western Digital My Book Essential 320GB...
how do I download files and pictures to an external hard drive and transfer info to another computer
If your external drive is connected to your computer, you can simply 'send to' or copy and paste.
Click on 'My Computer' and you will see the list of drives. You can then copy the files from their current folder and then paste to the external drive.
You can even 'drag and drop' the files!
Easy to do!!
Oct 05, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How do I completely reset my external hard drive
1. You need to check how much free disk space is available on your laptop.
2. You need to check what duplicated files you have on both the laptop and the external hard drive and which is the latest version.
3. You need to decide to move the latest versions of the data files from the external hard drive to the laptop. This automatically delete these from the external hard drive. The older versions on the external hard drive can be deleted.
4. Now you need to check how much data is stored on your external hard drive.
5. If the amount of data stored on the external hard drive exceeds the available disk space on the laptop, then you cannot copy these files to the laptop.
6. If you have sufficient disk space on the laptop you can copy the data from the external hard drive to the laptop. I suggest you make a folder to copy this data to it.
You can now delete all the data from the external hard drive or you can format the external hard drive to make a clean external hard drive.
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
external hard drive, how do I transfer to it?
If you using windows ME or newer the drive should show up under "My Computer" You can drag and drop files to it.
If the drive still has not shown up try these steps.
1. Make sure external drive power is on
2. If it came with software it may need to be installed first.
3. Plug in drive with computer off first. (usually not needed but may help)
4. Try the drive on another computer is possible to rule out faulty drive/usb adapter.
Some external drives require power from the computer, if this drive has no power adapter, you will want to ensure that you do not have a lot of other USB devices plugged in. You should hear a sound or get a message with the drive is detected.
Jei
Jul 21, 2008 | Computers & Internet
maxtor external back
plug in your external drive, and note it,s letter ( assigned device name ) i.e F/G/H et,c.
open your c:/ drive. highlight which items you want to copy over.
left click to highlight. then right click/Options/scroll Down Send to DriveF/G/H
And transfer, this should transfer what you want from 1 drive to another. But Don,t try to copy Windows. you.ll have errors as some of the sys files, will be in use whilst transfering.
mike @ compurepair.
Feb 20, 2008 | Maxtor Hard Drive
139 people viewed this tip
David Payne
David Payne
