Tip & How-To about Cell Phones
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
Cell Phones Logo
how do i detached the LCD assembly, do i have to solder the flex attach to the pcb or just pull it away to detach from the pcb?
Hello.
Welcome to Fixya's Community.
in order to fix your problem:
Please watch this its very helpful.
Also read this:
Problems With U700 Let's Fix it.
Thank you for Using Fixya.
Please let me know if you need any further help
Good Luck
Nov 05, 2009 | Samsung SGH-U700 Cellular Phone
Replace Flex-PCB in a Kenwood KDC-ps909
Don't remember but I think you need "Keys" a couple of funny shaped forks to press in the sides of the head unit...Frankly, if the PCB cable is bad (and you have one). Why not contact a local car audio dealer that sells Kenwood?
Good Luck
Jun 15, 2009 | Kenwood KDC-PS909
i have a verizon chocolate VX8500 (the new one) and the screen wont work
the phone needs to be service first then have to be reflash take the phone to a mobile service center and have them fix it for you.
Feb 12, 2008 | LG CHOCOLATE VX8500 Cellular Phone
white screen
okay you need to change both the LCD and flex cable
Jan 03, 2008 | Motorola Mobility RAZR V3
Earphone Connection
If you feel comfortable taking apart micr electronics then you can take off the case ans disassemble the chassis and see if its just the solder connections on the pcb. but be carefull sometimes they use flex pc boards and too much heat will burn up the board and then your dead in the water. Also it could be that the solder trace could have broken off the pcb. if this happens your gonna need to solder on a piece of small solid copper wire like phone cable (cat three type 26 guage)and run the other end to another solder connectionon the same trace. Them what I do is epoxie the connections and the jack so that its secure. Good Luck
Apr 27, 2006 | Creative Labs Zen Micro MP3 Player
468 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
