Tip & How-To about Computers & Internet
Big Brother And Ndisuio.sys, A new Intner phenomenon.txt
Ndisuio.sys, a very mysterious system file is present in Windows XP and is a driver for wireless things such as wi-fi and bluetooth. However, there have been many issues with this downloading immense amounts of data and perhaps causing activity that is "big brother"ish
The fact that hardly any information on this file downloading data is available by Microsoft makes things quite suspicious about it. It has even been noted that it looked as if it was transferring data to major companies like Comcast, Road Runner, Time Warner, BTC and Verizon.
The good news is, it turns out this file duplicates data that is sent/received, so wherever you go, it will also transfer the data to that file but if does not leave the computer/network so it's not spyware. So it's not as much of a big brother situation then it looks like. It simply performs internal communication tasks and stands for NDIS user I/O, hence, NDISUIO. NDISUIO is also used as a driver by many developers as it makes certain wireless network tasks easier such as implementing it for 802.11x connections. Some firewalls also use it as it can get the data in order to filter it.
But duplicating this data can hog resources for no reason, so disabling it is the best thing to do. The data rate of this file's received data is huge, so that indicates that the data transfer is not over the Internet, but locally. So it's just a duplicate of network activity but because it's local everything transfers faster but uses more resources then casual internet usage as there's more data involved at a given time span of 1 second, for example.
To disable this file, go to control panel, administration tools, services, Wireless Zero Configuration, double click and disable it. This file is probably required to run if you use any linksys wireless devices.
Computers & Internet Logo
after working for 2 days it will not allow us to connect to the internet then after i unplug the power then hook back up it works
In order to set wireless printer in Windows 7-based PC, you need to position it in a central location away from metal objects. Now, find out if it a Bluetooth or Wi-Fi as most new printers are equipped with either Bluetooth or Wi-Fi technologies. After, that enables the sharing of your printers by informing computer’s operating system about adding printer to its network. Also, install drivers for the same. Hence, in this way you can set up wireless printer on Windows 7-based system. You can also set up other computer systems in the network for using wireless printer get more information for Set Up Wireless Printer on Windows 7 .
Sep 06, 2010 | Linksys Wireless-G Broadband Router
i cant get the wireless connection
install drivers for it. download drivers from toshiba.com in their "download files" section
then find your models number..oh whilst you're there get some audio, video and bluetooth drivers on your way too.
Mar 04, 2009 | Toshiba Satellite A45-S151 Notebook
about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Feb 10, 2008 | Computers & Internet
124 people viewed this tip
David Payne
David Payne
