Tip & How-To about GPS
SLOW SATELLITE LOCK GARMIN NUVI GPS'S, ALL MODELS
IF YOUR GARMIN NUVI SERIES GPS IS SLOW TO PICK UP SATELLITE'S THEN THERE ARE TWO VERY EASY THING U CAN DO, 1ST GO TO WWW.MYGARMIN.COM AND REGISTER YOUR GPS WITH GARMIN, U WILL NEED A MINI USB CABLE FOR THIS AND A PC OR LAPTOP WITH INTERNET ACCESS, THEN CHECK FOR SOFTWARE UPDATES, THE ONE THAT HELPS SPEED UP LINK UP TO SATELLITES IS CALLED THE "HOTFIX" SOFTWARE ENHANCEMENT, INSTALL THAT SOFTWARE IF U HAVEN'T ALREADY DONE SO, 2ND THING IS TO LEAVE YOUR GARMIN ON A HOME CHARGER (AVAIL VERY CHEAP ON EBAY), WHEN U PLUG IT IN TO THE CHARGER THE GPS WILL COME ON, AS SOON AS IT DOES SLIDE THE POWER SWITCH TO THE LEFT, THIS WILL GIVE U A MESSAGE THAT "BATTERY IS CHARGING" LEAVE IT IN THE CONFIGURATION WHEN NOT IN USE, U WILL FIND WHEN U NEED TO USE THE GPS THE GPS WILL BE LINKED TO THE SATELLITE AS SOON AS U TURN IT ON, A SIDE BENEFIT OF THIS IS THAT BATTERY LIFE IS EXTENDED.
GPS Logo
registring nuvi
Hello there,
To register your garmin nuvi click on the link below: https://my.garmin.com/mygarmin/marketing/register.htm
To register your Garmin device, please visit the Garmin registration page online. To begin, select the type of product you wish to register then follow these easy steps based upon the product selected: Automotive devices: Sign in to your existing myGarmin account or select the option to create a new account (if one has not already been created)1 If prompted, select Continue on the page titled "Getting Started" Connect your device to your computer Follow the steps to install the Garmin Communicator Plugin2 Confirm the device information is correct and select Continue If you created a new myGarmin account, enter the required information and select Next (this step is skipped if using an existing account) Your device is now registered in your myGarmin account. Information on your device and possible updates will be provided on the Registration Complete page.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin nuvi 255W GPS Receiver
how do i register my sat nav
  • To register your garmin nuvi connect it to your computer with the mini USB lead
  • Go to www.garmin.com
  • Select your country from the drop-down list
  • Click on the "myGarmin" tab at the top of the screen
  • Click on "Register your garmin product" on the left of the screen
  • Click on "Automotive" and follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them again when you want to update your maps.
May 02, 2011 | Garmin Nuvi 2** series, Nuvi 2**t series,...
How do I register my Garmin nuvi 1400 series gps?
  1. Connect your satnav to your computer.
  2. Go to www.garmin.com
  3. Select your country from the drop-down list
  4. Click on the myGarmin tab
  5. Click on REGISTER YOUR GARMIN DEVICE and follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them to update your maps.
Nov 21, 2010 | Garmin GPS
i want to register a garmin nuvi gps system I find no registration information on the home page of www.garmin.com
The link to register your product is under the Support tab. But I have given a link for it below:
Good luck.
Feb 02, 2010 | Garmin Nuvi 255 GPS Receiver
where do i register my nuvi 205w series?
go to the link and follow the instructions, it is easy.
Nov 30, 2009 | GPS
1,152 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
