Tip & How-To about Food Mixers
GEARBOX DRIPPIN OIL KENWOOD CHEF
IF YOUR GEARBOX IS DRIPPING OIL TRY CHANGING THE GREASE INSIDE WITH SUPERLUPE FOODSAFE GREASE.AS YOUR OLD GRESE HAS PROBABLY BROKE DOWN AND LIQUIFIES. ALSO CHANGE OR WASH AND DRY THE FELT COVER UNDER GEARBOX.
**** AT KENWOODCHEFUSEDMIXERSANDSPARES.
07507400101
Food Mixers Logo
oil leaks out when tip up .around
KitchenAid uses a vegetable based grease inside of their mixers, it is a food safe grease. Because of this if you do not use your mixer often and over time the grease inside the mixer can begin to break down, and an oil will leak from the mixer.
What you will need to do is take the mixer apart, clean out the old grease and replace it with new KitchenAid grease, it is also recommended that you replace the gearbox gasket.
We are one of KitchenAid's largest service centers in the US, everything we sell is Genuine KitchenAid replacement parts.
Here is a link to the grease on our website: http://www.mendingshed.com/kagrease.html
And a link to the gearbox gasket: http://www.mendingshed.com/mixergasket.html
Also to aid you in the repair here is a link to the KitchenAid service manual for your mixer. this will show you how to take the mixer apart, replace the grease, and reassemble the mixer. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 30, 2013 | KitchenAid K45SS Classic Stand Mixer
OIL IS LEAKING OUT OF THE HEAD INTO FOOD BOWL. KITCHENAID SAID OK, FOOD GRADE OIL! I DON'T LIKE BLACK OILY CAKE OR COOKIES? CAN YOU HELP US TO FIX OURSELVES.
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
lp
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
May 26, 2009 | Kenwood KM300 Chef Stand Mixer
oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
kenwood chef.mixmaster
Apr 04, 2008 | Kenwood KM300 Chef Stand Mixer
1,354 people viewed this tip
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
