Tip & How-To about Computers & Internet
Recognize that your cd is a burner
To resolve this issue, edit the Microsoft Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives 4. On the File menu, click Export. 5. In the File name box, type backup of drives key, and then click Save.
Note You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved. 6. In the left pane of the Registry Editor window, click the Volume{GUID} folder under Drives, where GUID is a 32-character hexadecimal globally unique identifier.
Note If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive. 7. In the right pane of the Registry Editor window, double-click Drive Type. 8. In the Value data box, type 1 or 2, depending on the drive type, and then click OK.
The drive type should be 1 if it is a CD-R and 2 if it is a CD-RW. 9. Quit Registry Editor. 10. Click Start, and then click My Computer. 11. Under Devices with Removable Storage, right-click the CD-R drive or CD-RW drive, and then click Properties on the shortcut menu. 12. If the Recording tab is displayed, Windows recognizes the drive as a recordable device. 13. Click Cancel.
Note If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps: a. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose value you previously changed. b. In the Value data box, type 3, and then click OK.
The drive type value of 3 indicates that the drive is a standard CD-ROM and is not writable. c. In the left pane of the Registry Editor window, click the next Volume{GUID} folder. d. Follow steps 7 and 8 to change the Value data entry to 1 or 2, depending on the drive type. e. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is displayed in the properties dialog box of the CD-R drive or CD-RW drive.
Computers & Internet Logo
Refurbished Dell Optiplex GX280 with DVD/CD-RW Drive will not recognize blank CDs in order to burn music. I was told by the seller that I had to purchase burn software. (I also had to purchase CinePlayer DVD Decoder from Roxio in order to get the drive to play a DVD, although the seller did not mention it.) I tried to burn a Music CD in Windows Media Player 11. It would not recognize that a blank CD had been inserted. I had Roxio Creator MyDVD Combo LE on the PC I am replacing, so I installed it on the GX280, but Roxio does not recognize blank CDs either. IE8 was getting an add-on error for DLA too, so I uninstalled the Roxio software. I could buy Roxio Burn, but will that solve my problem? Microsoft says it will solve the IE8 compatibility issue, but will Roxio Burn recognize blank CDs on this drive? The drive is identified as DVD/CD-RW Drive (D). The Hardware properties state SAMSUNG CDR-W/DVD SN-324S but the type says DVD/CD-ROM drives. When I troubleshoot, only CD-ROM options are presented. The Recording properties state CD recording is enabled on the drive. Is this really a Combo Drive or am I only allowed to read CDs? What do I have to purchase to record music to a blank CD?
The windows might be corrupted. You could try editing the windows registry. here are the steps:
In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
last option, you could try installing imgburn. here's the download link: http://www.imgburn.com/index.php?act=download
If nothing happens, your dvd drive is bad.
Good Luck,
Ryan
Jan 16, 2011 | Dell OptiPlex GX280 Desktop PC - Intel...
Windows Vista recognizes the Memorex DVD- RW multi recorder w/Lightscribe device and the Lite-On CD-ROM device, yet fails to recognize the drivers sending an error code 10. It says the device is unable to start. How do I fix this problem?
You need to have a software driver download for the Memorex DVD-RW and Lite-on CD ROM. You can have it from the Internet. Just type at the Search engine blank (Download for driver of Memorex DVD-RW). Upon reaching the site, Choose the one with Windows Vista OS. Then, thereafter you can get the download for Lite-on CD ROM. After having the
download, go back to your PC menu and open the
download to install it. Once installed, test it. And job
well done.
Nov 27, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
cdwr code 41
To resolve this issue, edit the Windows registry to identify the CD-R drive or CD-RW drive as a recordable drive. To do this, follow these steps.
NOTE: You can restore this registry subkey by double-clicking the backup of drives key.reg file that you saved.
NOTE: If you have more than one CD-ROM drive in the computer, an additional Volume{GUID} folder is listed for each drive.
click Properties on the shortcut menu that appears.
12. If the Recording tab is displayed, the drive is successfully recognized by Windows as a recordable
device.
13. Click Cancel.
NOTE: If you have more than one CD-ROM drive, DVD-ROM drive, or CD-RW drive in the computer and the Recording tab is not displayed, an incorrect drive may have been configured as "recordable" in the Windows registry. To troubleshoot this issue, follow these steps:
1. Follow steps 1 through 9 to edit the Drive Type value of the Volume{GUID} folder whose
2. In the Value data box, type 3, and then click OK.
3. In the left pane of the Registry Editor window, click the next Volume{GUID} folder.
4. Follow steps 7 through 8 to change the Value data entry to 1 or 2, depending on the drive type.
5. Quit Registry Editor, and then follow steps 10 through 12 to confirm that the Recording tab is
XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
SYMPTOMS
After you install Microsoft Windows XP, the CD-ROM drive, the DVD-ROM drive, or CD-ROM R/W drive may not be visible in the My Computer window. Additionally, there may be question marks on the devices that are listed under CD-ROM drives in Device Manager.
CAUSE
An incorrect device driver was installed for the CD-ROM device.
RESOLUTION
To resolve this behaviour, use the following methods in the order in which they are presented.
Method 1: Remove Registry Entry
3. Locate the following registry subkey:
HKEY_LOCAL_MACHINE/System/Curretcontrolset/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes. NOTE: If this data type is missing, continue to the next method.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit the Registry Editor, and then restart the computer.
Method 2: Replace Existing Driver
1. Click Start, and then click Control Panel.
2. If Control Panel is in Category view, click Performance and Maintenance, and then click System.
-or-
If Control Panel is in Classic view, double-click System.
3. On the Hardware tab, click Device Manager.
4. Click the drive with the question mark next to it.
5. On the Action menu, click Uninstall. When you are prompted to confirm the removal, click OK.
6. Repeat steps 4 through 5 for any other drives with question marks.
7. On the Action menu, click Scan for hardware changes.
NOTE: If Windows XP cannot locate the driver for your device, the device may not be supported by Windows XP. To see the list of supported devices, see the most recent Windows Hardware Compatibility List (HCL) at the following Microsoft Web site:
SYMPTOMS
After you remove either compact disc (CD) recording software or other software from your computer, your computer may exhibit the following behaviour:
• In My Computer, there is no access to your CD-ROMs.
• In Device Manager, the following error message appears in connection with any CD-ROM device that is part of your computer system:
The device is not working properly because Windows cannot load the drivers required for this device
(Code 31).
• Device Manager displays the following error message:
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
You may also receive an error Code 39 message that indicates that the driver is corrupted.
• Device Manager displays the following error Code 19 message, which means that the registry returned some unknown result:
Your registry might be corrupted. (Code 19)
• You may also receive the following error message:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
RESOLUTION
To resolve this behaviour, follow these steps:
1. Start Registry Editor (Regedt32.exe).
2. Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
3. On the Edit menu, click Delete, and then click OK.
4. Locate the LowerFilters value under the same key in the registry:
5. On the Edit menu, click Delete, and then click OK.
6. Quit Registry Editor. NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
7. Restart your computer.
STATUS
This is a known issue that can occur when you remove Easy CD Creator version 5.01 or earlier or DirectCD version 3.01c or earlier. This issue may also occur with Easy CD Creator version 5.01 and with DirectCD 3.01d or later.
MORE INFORMATION
There may be other third-party CD-writing software products that exhibit similar behaviour. Some or all of the troubleshooting steps in this article might apply if such a product also adds entries under the UpperFilters or LowerFilters value in the registry, either by adding its own filter drivers or by removing the registry keys and values outlined in this article that begin with:
Oct 08, 2009 | Acer Computers & Internet
***** problem? it wont be recognized by compute, why oh why??? can you please help
try to change ur jumper setting of ur cd rom drive,set into master mode or slave mode! and try to change ur cd rom cable also.. check ur bios if ur cd rom drive is enable.
Jun 19, 2009 | Toshiba (P000242100) Internal 14x CD-ROM...
167 people viewed this tip
David Payne
David Payne
