Tip & How-To about Computers & Internet
Some speakers not working with your new souround sound system?
New 5.1 or 7.1 surround sound system?
1. Sounds easy enough, but its dark and hard to see sometimes behind your Pc. but make sure the cables are in the correct jacks.
2.Make sure u have a surround sound sound card. check on the internet product page of your pc.
3. Make sure the setting in control pannel>sound is set from stereo to 5.1 or 7.1 depending on what system u have and sound card capabilities.
4. If u have software that has a graphical interface that u can change settings for your sound card, u can change the stereo to 5.1 or 7.1
Computers & Internet Logo
How to stop music from playing music while surround sound is on the tv
First make sure the cables around the television and the surround sound system are not damaged. Then make sure the any grounding on the external sheathing of the cable is making good contact and that the braiding is not touching any other cable under the plug. You could try some better aftermarket connecting cables, and the ones that come with systems are used for price cheapness. Keep a space between cables and don't wrap them around each other. If none of that works, get some Ferrite Rings and thread three on each cable to the surround sound system, one at each end of the cable and one in the middle.
Cables with good braiding and gold flashed connectors as shown on this page are an indication of quality.
RCA Surround Sound Connections Analog 5 1 Audio Explained
Nov 06, 2016 | Audio Players & Recorders
how to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Surround sound playback problem
1. do a hard reset to factory settings.
2. do a surround sound test to make sure all sounds are coming to all speakers properly
3. check the cable from the main unit to the sub for any obvious problems. ie. plugged in securely etc etc.
it sounds like the cable from the main unit to the sub is faulty
good luck
smeags.
Dec 31, 2007 | Zenith DVT312 System
188 people viewed this tip
David Payne
David Payne
