Tip & How-To about Computers & Internet
Avoiding Driver Performance Problem.
So many people ask here about:
  • How can the connect the Front Panel Leads?
  • How can they Attach the Components on Board?
  • Where to attache a certain Lead?
  • What Properties do their PC have? etc
These questions are because that they dont know all these details are in the Motherboard's Manual (User Manual or Manual). they can fix a littlle problems like that while they see the manual. some people lose their manual and then dont know which model do they have and then stuck there.
here is the solution. There is a software called CPUZ (http://www.softpedia.com/progDownload/CPU-Z-Download-6980.html)
download the software from the link above,
run it. it will provide all the details about your PC including the model of the motherboard in the motherboard Tab. find the model and download the manual appropriate to your Mobo. you will find all the solutions for above mentioned problems.
So by this little Tip 20% - 30% approx. of the problems on this site can be solved.
Regards
Computers & Internet Logo
I have interl board.the fan of processor is working after some time disply come but after this the board not working.pl.help
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 25, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
display is not coming of my desktop. i have used all possible way expect mother board.
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Intel Desktop Board D845EPI Motherboard
When computer Switch On button press computer will not be start and processor fan aslo not start so which problem accured on mother board or cpu? But Motherboard light is always on board provide power to all components on board but when on button press computer not start and also fan off. plz help me
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 07, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
114 people viewed this tip
David Payne
David Payne
