Tip & How-To about Office Equipment & Supplies
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
i whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
hello'' can you tell me how to change the ink in the kodak printer?
  1. Open up the cartridge to reach the ink chamber within. For color and photo cartridges, just remove the lid with a sharp knife (insert it where the black and colored plastic meet) to find the three fill holes. On black cartridges, make a hole with a heated pin or drill on top of the cartridge where the letter "K" is.
  2. Step 2 Check the chambers in a color/photo cartridge to determine which color ink is in which chamber. Insert a different toothpick or pin into each chamber to draw out yellow, cyan or magenta ink.
  3. Step 3 Fill a plastic syringe bottle with enough ink in the color you are refilling. A black ink cartridge should need 10 to 15 milliliters. A color/photo cartridge takes 5 milliliters of each color.
  4. Step 4 Insert the syringe needle into the cartridge, sending the tip down to the bottom. The chamber contains a sponge, so you will need a small bit of force to push it in.
  5. Step 5 Inject the ink into the cartridge. Unlike other brands of cartridges, you want to saturate the sponge with ink in a Kodak cartridge. Depress the syringe plunger slowly until you can see the ink begin to surface on top of the sponge.
  6. Step 6 Wash all ink residue out of the syringe after you've refilled one shade of ink. If you intend to refill another color immediately, dry the syringe out first.
  7. Step 7 Replace the lid on a color/photo cartridge. Apply a strip of tape to the spot where you first removed the lid to secure it. You don't need to seal a hole you drilled in a black cartridge.
  8. Step 8 Leave the cartridge standing in a secure spot overnight. This helps the ink settle within the cartridge for even printing once the cartridge is back in the printer.
Apr 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HOW TO REFILL
I love to give the answer for your question but we don't know which printer model you are talking ?
Following the the common procedure for refilling the Ink Cartridge
COLOR CARTRIDGE
BLACK CARTRIDGE
Jan 22, 2010 | HP Office Equipment & Supplies
Ink cartridge stops at the middle of my printer.
Problem : An error occurred while communicating
Afteryou install a print cartridge, the attention light begins to flash red.The printer will not print. One of the following messages may appear onthe control panel:
or the Printer stops Printing in the middle .
Cleaning the Still Rode on which the Cartridge Move, may solve your Problem
Check this Video - This may help you a Lot VIDEO
Check the following steps as well for connection steps .. and also the process of refilling the Ink to the Cartridge
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Solution :
Tosolve the problems related to Cartridge Errors we can do the following4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reseat the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat reseating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step 1: Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE: you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
COLOR CARTRIDGE
2.Using the picture(on the cartridge which shows you the 3 differedcolored spots), fill syringe with the corresponding color ink.
BLACK CARTRIDGE
2.Push the syringe all the way into the filling hole and SLOWLY injectall the ink into the cartridge or until the reservoir is full.
Jan 04, 2010 | Dell V305w All-In-One R840635AU InkJet...
hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
278 people viewed this tip
jasbo
jasbo
