Tip & How-To about Office Equipment & Supplies
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
My Sharp AL-1551CS,drum ligth came on and say needs drum,so bugth new one instaled di d some coping and now ligth drum came on againg and does not want to print. I do not have the manual!
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 29, 2010 | Sharp AL-1551CS Copier
I replaced a new drum cartridge for Sharp AL-1631 Copier, but the warning indicator light is still on and the copier is not working.
Sep 17, 2010 | Sharp AL-1641CS Color Copier
Upon replacing the drum on my Sharp AL-1631, the drum indicator light is still illuminated and the copier still won't function. Is there something I need to do after replacing the drum to get it to copy again? People have been talking about resetting the drum counter, but I don't see anywhere in which to do that. Please help!
To reset the drum light on your Sharp AL1631 series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Turn the machine off then on again and your drum light should be gone.
Sep 08, 2010 | Sharp AL 1631 Copier
I have a sharp AL 1655cs printer copier and I have replaced the drum cartiage but it still says that it needs a new one is there a way to reset so it knows there is an new cartage in it?
Sep 06, 2010 | Sharp AL-1655CS Copier
AL 1631. Indicates that a drum has to be
To reset the drum light press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Feb 13, 2010 | Sharp AL 1631 Copier
1,901 people viewed this tip
jasbo
jasbo
