Tip & How-To about Washing Machines
Replacing a Water Pump on Whirlpool Top Loaders
This advice is for Whirlpool manufactured TOP LOADING washing machines equipped with a DIRECT-DRIVE type transmission. This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. This is a simple repair that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
c. Other models have screws located along the back of the console that are loosened to release the console.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Locate the water pump. It is a small plastic pump with two hoses connected to it, directly under the front of the wash tub. It is advisable at this point to drain the residual water from the wash tub. This will save you a lot of clean up time later.
Here’s a helpful HINT: If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall. Connect the shop vac to the end of the drain line and pull a vacuum on it. This will quickly drain the residual water and leave you with little to no mess. If you do not own a shop vac, remove the lower hose from the pump and place a pan or a bunch of old towels under it & allow to drain.
8. Remove the water pump by removing the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and remove both hoses.
HINT: This is a good time to inspect the drain lines for any debris that may have gotten lodged in the lines.
9. Install new water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly on the motor shaft. Make sure you re-install the retaining clips correctly. Insert the keyed end first, then turn and snap them in place over the pump.
10. Re-install washer case. With the lid of the washer open, grasp the washer case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame front and rocked back onto the side frames, ensuring that the small cleats on the frame fit into the slotted grooves on the washer case side panel base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
11. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
12. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
13. Reinstall console.
NOTE: This water pump IS NOT serviceable. You can, at times, manage to dislodge items that have become stuck in the pump by slowly rotating the shaft backwards (with the pump removed from the washer) while pulling the object free. Sometimes this works, but sometimes the seal becomes damaged. Panty hose, underwear and the under wire from bras are notorious for getting stuck in these pumps.
HINT: It is STRONGLY recommended that you use small nylon garment bags while washing some of your smaller items like this.
The average price for a new washer pump should cost about $30 - $40.
NOTE: This instructions apply to Kenmore, Kelvinator, Frigidaire, Estate and some later model Maytags manufactured by Whirlpool. If in doubt, plese include your MODEL NUMBER when posting questions.
Washing Machines Logo
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
My whirlpool top loader extra large washing macine
Many late model washing machines use a direct-drive system to agitate and spin. They don't use belts or pressure wheels to transfer power and motion from the motor to the transmission. The motor is coupled directly to the transmission. If the motor is running and there is no agitation or spinning of the tub, the culprit is usually a plastic coupling between the motor and transmission or the transmission itself.
Aug 07, 2008 | Washing Machines
My washing machine has a broken drive belt!
Not a good model number, so I can't be positive on this. All whirlpool top load washers built in the last 25 years are no longer belt driven, they are direct drive, Broken drive coupling is a very common problem. If you have a wp washer older than 25 years with a drive belt, I don't recommend you repair it as there are a number of major repairs at the same time. Outer tub major corrosion, leaks small amounts of water onto the base plate and then into the wig-wag assembly(electrical shock hazard), main bearing-basket drive assembly, water pump bearings and seal fail(this is usually what burns out the belt. Ect, ect. For Repair manuals try Reliable Parts Co. at 1800-666-0313 Good Luck, Appliance Specialists
Dec 17, 2009 | Whirlpool Washing Machines
Is there a spin clutch adjustment on a kenmore older model washing machine
This assumes that your washer is a top loading unit.
There isn't a clutch adjustment on Kenmore / Whirlpool top loader, direct drive washers.
Sears does have a clutch rebuild kit however.
See the Sears site:
http://www.searspartsdirect.com/partsdirect/index.action
and enter your model number.
A list of sub-components should come up.
Click on the motor and clutch link and you should see parts for a complete clutch and the band and lining kit.
Replacing either requires removing the cabinet, agitators, pump, motor and transmission.
Then removing the clip that holds the clutch to the top of the transmission and either replacing the entire clutch or just the band and lining.
Sep 19, 2009 | Kenmore Washing Machines
Washer makes noises
You said, when the washer is going into spin cycle it makes a loud clunking noise. You are wondering if this could be the brakes or possibly the pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
it can also be a broken spring or strut dependping on your washes make and type
Please remember to leave a rating
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
4,261 people viewed this tip
Top Washing Machines Experts
