Tip & How-To about Computers & Internet
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
Computers & Internet Logo
i cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
i made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
how do i reboot or recover my nb505 toshiba netbook
Reinstall Windows from a Disk
1 Turn on your Toshiba . Insert your recovery disk or the original Windows operating system DVD
into the 's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba . In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba . In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba NB505N508BL 10.1" Intel Atom...
computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
303 people viewed this tip
David Payne
David Payne
