Tip & How-To about Linksys Wireless-G Broadband Router
How to resolve Intermittent Wireless connection using Linksys routers....
If your problem is with the wireless connectivity on all your wireless computers, there is a possibility that you are experiencing interference. Any device working on a 2.4-GHz frequency would cause reception problems on your wireless adapters. You can help by checking the following factors, all of which can greatly affect your wireless signals:
1. 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default is 6) and restart the wireless computers.
To change channel on your router follow the steps below:
a. Log on to the router's web utility (http://192.168.1.1 on your browser). Then put the router password admin and leave the username blank but if you change the router password then type that in.
b. On the wireless section, change the channels from 1 to 11. I suggest you to use channel 1, 6, 9 and 11. Hit Apply or Save Settings.
2. Physical obstructions: Your router or wireless computers may be loosing connectivity because of physical obstacles, including walls and floors. Try to physically move the equipment to different locations to find a better link.
3. Placement of the router: I suggests that you place your router as high off the ground as possible. If placing in a high location, be sure to give leave a distance of 2-feet between the router antenna tips and the ceiling and wall. If your signal goes through multiple floors, try to place the router on the upper-most floor, and up high in the room that it will be placed in.
4. Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
If you have enabled the WEP security on your router try the following steps to troubleshoot the problem:
From the wireless computer you are having problem with, if you are using Windows xp make sure the IEEE for the authentication is not enabled. To check this go to Control panel>Network connections>Right click on Wireless network connections then hit the properties button. Click on Wireless networks tab and under the Preferred networks highlight the name of your wireless network then hit the properties button. Click on the Authentication tab and make sure that the Enable IEEE box is not check.
If you don't have WEP security enabled on the router and changing channels didn't help to fix the problem you may try to enable the wireless security on the router. To enable WEP on the router follow the steps below:
1. Open your default browser and enter the following IP address into the address bar:
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will need this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
If it still doesn't work try to uninstall and reinstall the driver of the wireless adapter. You may try to use the latest driver of the adapter that was available on our website. If you are using Windows xp you don't need to install the WLAN utility for the card, install only the driver.
If it still doesn’t work you try to hard reset the router. If you will reset the router it will turn to the factory default settings of the router and you need to reconfigure it.
To reset the router to factory default 1] Press and hold the reset button for 30 sec., after that 2] Unplug the power keep holding down the reset button for another 30 sec. 3] Then, plug back the power keep holding down the reset button for 30sec., after that 4] Release the reset button. 5] You need to reconfigure the router again and that should correct everything...
If this is a Helpful tip Thumbs Up is appreciated. Thank you
Linksys Wireless-G Broadband Router Logo
loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
Feb 18, 2011 | Linksys WRT120N Router
The router often looses wi-fi signal and dhcp gives wrong address ( exemple: 169.164.....)
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
  • Customizing Wireless Settings of the Router
    Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
    1)To change the router's SSID or the wireless network's name, click here.
    2)To change the router's channel, click here.
    3)To enable the wireless security on the router, click here.
    NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
Dec 14, 2010 | Linksys WRT120N Router
my intenet connection is very slow due to my router
This mentions Linksys, but it relates to all routers
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Nov 04, 2009 | Computers & Internet
Extremely inconsistent connection to router (Net Gear) & Internet
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Netgear router.
  2. Wireless settings of the Netgear router are still set to default.
  • Placement of the router:Netgear suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Customizing Wireless Settings of the Router:
Having default wireless settings on the Netgear router may cause conflict with other Netgear routers within your network range.Netgear suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | Computers & Internet
internet connection drops every 15 minutes
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
  2. Wireless settings of the router are still set to default.
  • Placement of the router: Mfg. suggest that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
Having default wireless settings on the router may cause conflict with other routers within your network range. Mfg.suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
Thanks, Joe
Jun 12, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
1,614 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
