Tip & How-To about Cell Phones
How to protect your Phone from Unauthorized Use ?
To protect your phone from unauthorized use Sony Ericsson
Go to Menu > Settings > General > Locks > SIM Lock > Protection.
To protect your phone from unauthorized use, just follow these simple steps. Once activated, your phone will require the user to enter a password each time it’s turned on.
To turn your PIN code request on, you will be prompted to enter a 4 to 8 digit phone code (that you create) Call Customer Care to obtain a PIN/PUK code to enter at the prompt.
Note: You will have 3 chances to correctly enter this code. If you incorrectly enter it 3 times, you will see "SIM Blocked" and should visit your nearest retail location to purchase a new SIM card.
Cell Phones Logo
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
Mar 12, 2011 | Sony Ericsson Cell Phones
how to change code to "0000"?
To activate the phone lock protection:
  1. Select Menu > Settings > General (tab).
  2. Select Security > Locks > Phone protection.
  3. Select Protection > On.
  4. Enter the default phone lock code "0000".
  3. Select Change code and follow the instructions.
Mar 01, 2011 | Sony Ericsson K530i Cellular Phone
i want to put password protection for k550i sony
To protect your phone from unauthorized use, just follow these simple steps. Once activated, your phone will require the user to enter a password each time it?s turned on. Go to Menu > Settings > General > Locks > SIM Lock > Protection. To turn your PIN code request on, you will be prompted to enter a 4 to 8 digit phone code (that you create) Call Cincinnati Bell Customer Care at 611 to obtain a PIN/PUK code to enter at the prompt. here is the link k550i Happy new year and Happy Sunday
Jan 03, 2010 | Sony Ericsson K550i Cellular Phone
unlock codes
http://www.sonyericsson.com/cws/support/phones/detailed/phonelockcodeissues/w910i?lc=en&cc=nz
or
  1. From standby, go to 'Menu' > Settings > General (tab).
Apr 07, 2009 | Sony Ericsson W910i Cellular Phone
how to lock the keys
If it is a flip phone, most flip phones dont offer the ability to lock the keys because they are thinking there isn't a need for that since the keys are hidden by the top of the phone, if it is a candybar phone usually the menu key and the * (star) key are used to lock and unlock your phones, if its a smart phone there may be some options in the settings. You didnt mention what brand your phone is based on the model number sounds like a samsung. you can go to samsungs website and research the model number and usually they have information on how to do everything you need with the phone. most cell phone carriers have this info too, you may have to dig threw the website a little though
Dec 29, 2008 | Sony Ericsson Z610i Cellular Phone
133 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
