Tip & How-To about Computers & Internet
"BURN" YOUR FAVORITE "XBOX GAMES"
BURNING X-BOX & GAMECUBE GAMES USEING CDRWIN
1) Insert your original in your CD-ROM.
2) Open CDRWin (or any other image extractor) to make an iso image of the game
on your hard disc. Click on 'Extract Disc/Tracks/Sectors'
3) Here are the settings which work for me (!):
Disc Image/Cue sheet
File-Format: Automatic
Reading-Options:
RAW, CD+G, CD-TEXT and MCN/USRC all Unchecked
Error Recovery: Ignore
Jitter Correction: Auto
Subcode Analyses: Fixed
Data-Speed: MAX
Read Retry Count: 10
Audio Speed: MAX
Subcode Threshold: 900
There are a lot of reports, that Raw reading also works, but I had problems with it enabled.
4) Click on 'Start'
RECORDING TO A DISC
1) Install Fireburner
2) Double click on the Cue File For The Game
3) Right Click And select burn To CD
That?s all there is record DAO, and you can try to burn it fast at 2X
Using PNY Black Diamond CDR'
Computers & Internet Logo
i have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
My playstation 1 wont play games and just say please insert cd rom? It plays music but not games...Do I need a ps1 cd rom? is there one?
it sounds like your laser is either dirty or it needs replaced. when a laser starts to go they usually will play music but not any games or movies.
Jul 29, 2009 | Video Game Consoles & Games
windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
144 people viewed this tip
David Payne
David Payne
