Tip & How-To about Televison & Video
How to see if your tv remote is working
A digital camera can see the IR (Infra-red) light generated by your television or any IR remote!
point the remote (with good batteries) at the digital camera and press a button. If it is working you will be able to see the flashes on the digital camera screen.
In this way you will be able to track down the cause of your remote control problem by eliminating or confirming whether the remote is dead, or if the fault is that the receiving unit (TV, vcr, dvd, etc) is not receiving or the code is wrong.
good luck
Televison & Video Logo
onkyo tx ds777 remote does not working
If battery replacement does not work, your remote control probably has failed.
Dec 20, 2017 | Onkyo Audio Players & Recorders
Remote won't work but can manually operate
you do the camera tricks just to ensure if the infra red sensor of the remote is working. get a digital camera turn it on,then get the remote controller. press any button at the remote controller pointing to the digital camera, if you see a light at the display of the camera then the infra red sensor is good but if no light either the sensor is worn out or the circuit was defective.
Dec 07, 2012 | Curtis DVD1041 Player
remote not working changed batteries lights up but doesnt work
Use a digital camera so "see" the Infra Red (IR) beam coming from the top of the remote. Try a few known good remotes with the camera to get the hang of it, then try the suspect remote. If you don't see the light, the remote will need to be replaced. If you see the light, the problem is with the IR receiver within the TV.
Mar 15, 2010 | Proscan PS36600 36" TV
purchased a JNC LCD television 2yrs ago remote will not work not a battery problem have tried number of diffrent batterys
Mar 15, 2010 | Televison & Video
How do I test A battery?
Connect the RED probe(+) to the Pointed side of the battery and the other probe(-) to the other side of the battery.
Also try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
Jan 25, 2009 | RCA Universal Remote Control
184 people viewed this tip
Top Televison & Video Experts
