Tip & How-To about Computers & Internet
By following a few simple guidelines, you can maintain your computerand keep it running smoothly. This article discusses how to use thetools available in Windows 7, Vista, and XP Service Pack 3 (SP3) tomore efficiently maintain your computer and safeguard your privacy whenyou're online. 1. Free up disk spaceThe Disk Cleanup tool helps you freeup space on your hard disk to improve the performance of your computer.The tool identifies files that you can safely delete, and then enablesyou to choose whether you want to delete some or all of the identifiedfiles. Use Disk Cleanup to: Remove temporary Internet files. Remove downloaded program files (such as Microsoft ActiveX controls and Java applets). Empty the Recycle Bin. Remove Windows temporary files such as error reports. Remove optional Windows components that you don't use. Remove installed programs that you no longer use. Remove unused restore points and shadow copies from System Restore. Tip:Typically, temporary Internet files take the most amount of spacebecause the browser caches each page you visit for faster access later. 2. Speed up access to dataDisk fragmentation slows theoverall performance of your system. When files are fragmented, thecomputer must search the hard disk when the file is opened to piece itback together. The response time can be significantly longer. DiskDefragmenter is a Windows utility that consolidates fragmented filesand folders on your computer's hard disk so that each occupies a singlespace on the disk. With your files stored neatly end-to-end, withoutfragmentation, reading and writing to the disk speeds up. When to run Disk Defragmenter In addition to running Disk Defragmenter at regular intervals?monthlyis optimal?there are other times you should run it too, such as when: You add a large number of files. Your free disk space totals 15 percent or less. You install new programs or a new version of Windows. 3. Detect and repair disk errorsIn addition to running DiskCleanup and Disk Defragmenter to optimize the performance of yourcomputer, you can check the integrity of the files stored on your harddisk by running the Error Checking utility. As you use your harddrive, it can develop bad sectors. Bad sectors slow down hard diskperformance and sometimes make data writing (such as file saving)difficult, or even impossible. The Error Checking utility scans thehard drive for bad sectors, and scans for file system errors to seewhether certain files or folders are misplaced. If you use your computer daily, you should run this utility once a week to help prevent data loss. Run the Error Checking utility: Close all open files. Click Start, and then click My Computer. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties. In the Properties dialog box, click the Tools tab. Click the Check Now button. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start If bad sectors are found, choose to fix them. Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors. 4. Protect your computer against spywareSpywarecollects personal information without letting you know and withoutasking for permission. From the Web sites you visit to usernames andpasswords, spyware can put you and your confidential information atrisk. In addition to privacy concerns, spyware can hamper yourcomputer's performance. To combat spyware, you might want to considerusing Microsoft Windows Defender, which is included in Windows 7 and Windows Vista, and is available as a free download for Microsoft XP SP2. Alternatively, there are other free anti-spyware software programs available. 5. Learn all about ReadyBoostIf you're using Windows 7 orWindows Vista, you can use ReadyBoost to speed up your system. A newconcept in adding memory to a system, it allows you to use non-volatileflash memory?like a USB flash drive or a memory card?to improveperformance without having to add additional memory.
Computers & Internet Logo
Name and explain at least 6 guidelines for placing of fire extinguishers.
Google is your friend in such cases. Read all the pages and make your own findings.
  • Emergency Standards ' Portable Fire Extinguishers ... https://www.osha.gov/SLTC/etools/evacuation/portable_placement.html Portable Fire Extinguishers Extinguisher Placement and Spacing. ... The following guidelines will help you identify the number and types of portable fire ...
  • A Health and Safety Guideline for Your Workplace Fire ... iapa.ca/pdf/FreeDownloads8_fireext.pdf · PDF file Fire Extinguishers © Industrial Accident Prevention Association, 2006. All rights reserved. 1 A Health and Safety Guideline for Your Workplace
  • Placement of Fire Extinguishers in the Workplace safeandcompliant.net/safe-kb/article.php?id=30 Placement of Fire Extinguishers in the Workplace. KB Home ... The following guidelines will help you identify the number ... Fire Extinguisher Size and Placement ...
  • Portable fire extinguishers. - 1910.157 - osha.gov https://osha.gov/pls/oshaweb/owadisp.show_document?p_id=9811&p... 1910.157(a)Scope and application. The requirements of this section apply to the placement, use, maintenance, and testing of portable fire extinguishers provided for ...
  • Guidelines to the Strategic Placement of Fire ... driftwoodontheocean.com/2016/04/11/guidelines-to-the-strategic... Fire Extinguisher Safety and Other Essential ... of placing the fire extinguishers in the ... to place your fire extinguisher, here are a few guidelines to ...
  • Geeks On Home: OSHA Fire Extinguisher Guidelines www.geeksonhome.com/...7717356_osha-fire-extinguisher-guidelines.html OSHA Fire Extinguisher Guidelines. ... The Occupational Safety and Health Administration maintains rules governing how fire extinguishers are used, ...
  • Fire Extinguisher Requirements and References in the ... amerex-fire.com/wp-content/uploads/2013/02/Fire-Extinguisher... · PDF file Fire Extinguisher Requirements ... there are additional requirements for placement, ... servicing and training with portable fire extinguishers beyond the ...
  • Fire Detection and Extinguishing Equipment Regulations laws-lois.justice.gc.ca/eng/regulations/C.R.C.,_c._1422 ... Fire Detection and Extinguishing Equipment Regulations ... Special Requirements; 7 ... Portable Fire Extinguishers; 90 ...
  • http://www.bing.com/search?q=guidelines+for+placement+of+fire+extinguishers&qs=n&form=QBRE&pq=guidelines+for+placement+of+fire+extinguishers&sc=0-46&sp=-1&sk=&cvid=405F1FDF23E64C4A8BD1FC6B5358AE64
    Jul 10, 2016 | Cars & Trucks
    Jan 07, 2010 | Computers & Internet
    i have dell inspiron 5160 is very slow n getting problem in more time now problem is laptop wanted boot ,where is problem i dont know but stopped in unwanted time n after
    5 ways to speed up your PC
    By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and http://www.microsoft.com/atwork/maintenance/speed.aspx#">XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
    The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
    • Remove temporary Internet files.
    • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
    • Empty the Recycle Bin.
    • Remove Windows temporary files such as error reports.
    • Remove optional Windows components that you don't use.
    • Remove installed programs that you no longer use.
    • Remove unused restore points and shadow copies from System Restore.
    Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
    To use Disk Cleanup
    Window 7 users
    1. Click Start, click All Programs, click Accessories, click System Tools, then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
    2. When Disk Cleanup has calculated how much space you can free, in the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
    3. MORE INFORMATION GO TO THIS LINK: http://www.microsoft.com/atwork/maintenance/speed.aspx
    Dec 06, 2010 | Dell Computers & Internet
    how can i speed up my aircel internet on pc
    5 ways to speed up your PCBy following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
    1. Free up disk spaceThe Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
    2. Speed up access to dataDisk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
    Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.
    In addition to running Disk Defragmenter at regular intervals—monthly is optimal—there are other times you should run it too, such as when:
    • You add a large number of files.
    • Your free disk space totals 15 percent or less.
    • You install new programs or a new version of Windows.
    3. Detect and repair disk errorsIn addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.
    As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.
    1. Close all open files.
    2. Click Start, and then click My Computer.
    3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
    4. In the Properties dialog box, click the Tools tab.
    5. Click the Check Now button.
    6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
      checkdisk.jpgExample of Check Disk Local Disk dialog box
    7. If bad sectors are found, choose to fix them.
    4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using the PC safety scan from Windows Live OneCare. This scan is a free service and will help check for and remove viruses.
    5. Learn all about ReadyBoostIf you're using Windows 7 or Windows Vista, you can use ReadyBoost to speed up your system. A new concept in adding memory to a system, it allows you to use non-volatile flash memory—like a USB flash drive or a memory card—to improve performance without having to add additional memory.
    Jun 13, 2010 | Microsoft Windows XP Professional for PC
    94 people viewed this tip
    David Payne
    David Payne
