Tip & How-To about Computers & Internet
Cannot use my password to get back into Windows XP
Because of the security features built into Windows XP, it is virtually impossible to get back into the system without the password. You have several options to try and get around this problem.
If you have the access to another user account with administrator rights, you can use that account to change the password of the account that is locked out. You can also use the default Administrator account that is built into Windows XP.
First you need to boot the system into the Safe Mode.
1. Restart your system.
2. When you see the blue Dell globe or screen, press the ( F8 ) key about 3 times a second.
3. You should get the windows startup menu. Use the (up or down) arrow keys to highlight (SafeMode)
4. Press (Enter) on (SafeMode), then press (Enter) on (Windows XP).
5. The system should boot to Safe Mode.
Once you are at the Account Log on Screen, click on the icon for the user account with administrator rights, or click on the icon for the administrator account.
Note: For Home the Administrator account isn't normally shown & in Safe Mode you have to press Ctrl+ALt+Delete keys twice to show. For PRO you cando this in normal mode
When the system has booted to the desktop, use the following steps to change the accounts password.
1. Click Start, Control Panel, Administrative tools.
2. Click Computer Management.
3. Double click Local Users and Groups, double click the folder users.
4. Right click on the account name that is locked out, and click on Set Password.
5. You may get a warning message about changing the password, simply click proceed.
6. Leave the New Password box blank , also leave the Confirm Password box blank.
7. Click OK, and OK again.
8. Then close all Windows, reboot the system and try to log in.
There are also applications that can recover the password for you. The following companies provide these applications at a cost.
iOpus* Password Recovery XP here.
LostPassword.com, here
Asterisk Password Recovery XP v1.89 here.
Windows XP / 2000 / NT key here.
If the above information does not help in recovering the password, the only option left is to format the hard drive then reinstall Windows and system software.
Computers & Internet Logo
can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
i need to find my network password can you help?
The password should be stored in any computer which has connected to that router via wireless.
If that computer has Windows 7, there is a built-in function to display the password. Go to:
Start > Control Panel > Network & sharing > Manage wireless
That will being up a list of routers. Find the correct one, right-click and select "Properties".
That will bring up an info box for that router. Select the "Security" tab, The security key (password) will be hidden behind asterisks. Place a check in the box for "Show characters". That will display the password
If the computer which has connected to the router has an older operating system (Vista or Windows XP), then you may not have that built-in password display feature. But you may still be able retrieve the password by installing some specialized software.
Here are two suggested free software programs to display wireless passwords:
WirelessKeyView by Nirsoft:
http://www.nirsoft.net/utils/wireless_key.html
http://www.softpedia.com/get/Security/Decrypting-Decoding/WirelessKeyView.shtml
Advanced Password Recovery by Josh Cell Software:
http://www.joshcellsoftwares.com/2011/08/advanced-password-recovery-password.html
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Advanced-Password-Recovery.shtml
Jan 01, 2012 | Computers & Internet
i need to hange the security password in order for me to use my laptop but my niece forgot the security key password and i need to change it
The password should be stored in your niece's laptop, or any other computer which has connected to that router.
Sep 27, 2010 | Belkin (F5D8231-4) Wireless Router...
my laptop is asking me for a supervisor password and i dont have it
If you have lost windows password, the best thing for you is creating a password reset disk.Actually,when you add a password to your pc,the first thing you should do is creating a disk in case you lost the password.But how to make a password reset disk after you have lost the password ? Follow these
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Key
Then let's begin
Step 1.Login to a PC which can link to internet,Download and install the program from http://www.lostwindowspassword.com in that PC
Step 2.Run the program and burn to CD/DVD OR USB flash drive
Step 3.Turn to your locked PC,insert the newly create CD or USB to your drive.Reboot the Computer and then follow the instructions,it is very easy to use.
Mar 09, 2010 | Acer Aspire 5050-3242 Notebook
127 people viewed this tip
David Payne
David Payne
