Tip & How-To about Office Equipment & Supplies
How to reset an HP printer waste ink tank aborber (only work on certain models)
Press and hold the '*' key on the key pad,
then press the '#' key and release them both.
Then enter '123' to enter maintenance mode.
Press the right arrow (beside the OK button) until System Config menu appears on the panel.
Then press OK two times to clear the error condition, Then press cancel two or three times to return to the top menu.
Then power off and back on, print a test page
If this does not work there is another method that may work I have posted a TIP for as well.
Ink System Failure
Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on
May 10, 2014 | HP Photosmart C7250 All-In-One Thermal...
I have this code 0xc19a005
This message means that the ink system has failed on your printer most likely caused by the print head overheating. The only solutions available for this issue WAS to either replace the print head or replace the printer BUT ...... DO THIS ::::
NOTE: CHANGE EMPTY CARTRIDGE BEFORE DO THAT:
press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. then press the right arrow (beside the OK button) until System Config. menu appear on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, print a test page .
Mar 24, 2014 | HP Photosmart D7360 All-In-One InkJet...
How to enter maintenance mode KM 3050
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Dec 03, 2013 | Kyocera Mita KM-3035 All-In-One Laser...
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
Experiencing a problem with an HP Photosmart C7280 All-in-one printer, after the yellow ink cartridge was replaced a 'change the cartridge' screen comes up when trying to print, even though the printer shows the new ink levels are OK with the newly installed yellow cartridge. Just installed the current updates for the HP C7280 and problem still persists. Any thoughts?
You may also try this: Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Then press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then power it off and back on.
May 11, 2010 | HP Photosmart C7280 Printer
288 people viewed this tip
k24674
