Tip & How-To about Canonical Ltd. Ubuntu
Fix sound problem in Ubuntu
Off a fresh install of Ubuntu (GNU/Linux) there is often a problem withthe sound not working right away. I have found a simple fix for thiswhich does not require additional drivers or any downloading. Istarted with a fresh install of Ubuntu 9.10 Karmic Koala.
First, right click on the speaker icon at the top near the clock and select Sound Preferences.
Turn up the "Alert volume" to about 75-100%, make sure it's above half,the default is 50%. Also make sure the Output volume is near 100% also.
Now this next step is where the magic happens:
Then tab over to the Hardware tab in the preferences. At the bottom of this tab you will see "Settings for the selected device:" and below that is "Profile:" This is where you will mouse over the "AnalogStereo Duplex" flick the mouse wheel up once so it reads "Analog StereoOutput" and then flick the mouse wheel down again back to "AnalogStereo Duplex". Close the properties now, and the sound should work. (If you don't have a mouse wheel, just left click on it to change the selections.)
Also from time to time, something goes down with pulseaudio (the sound) and simply running this command in a terminal window will bring it back to life.
This is the command:
sudo killall pulseaudio
All this command does is kill all processes using the audio, therefore refreshing the audio devices and freeing it up. This does not remove any packages or drivers, just stops all processes using audio. If you are playing a song in Rhythmbox, you will have to restart the song again, no problems there.
This command I have tested with Ubuntu and Mint and works with both, I imagine it works in all Debian-based Linux distributions. I hope you found this information helpful, if so please rate me with the blue thumbs!
Canonical Ltd. Ubuntu Logo
how to enable bluetooth on lenovo s10-3t ?
install "blueman"
i don't know what operating system you are using, but on ubuntu, open a terminal and type "sudo apt-get install blueman"
Feb 18, 2014 | Lenovo IdeaPad S10-3t 10.1in Netbook...
how do i get to recovery mode for ubuntu?
  1. Switch on your computer.
  2. Wait until the BIOS has finished loading, or has almost finished. (During this time you will probably see a logo of your computer manufacturer.)
  3. Quickly press and hold the Shift key, which will bring up the GNU GRUB menu. (If you see the Ubuntu logo, you've missed the point where you can enter the GRUB menu.)
  4. Select the line which starts with "Advanced options".
  5. Select the line ending with "(recovery mode)", probably the second line, something like: Ubuntu GNU/Linux, with Linux 3.8.0-26-generic (recovery mode)
  6. Press Return and your machine will begin the boot process.
  7. After a few moments, your workstation should display a menu with a number of options. One of the options (you may need to scroll down to the bottom of the list) will be "Drop to root shell prompt". Press Return with this option highlighted.
  8. The root partition is mounted read-only. To mount it read/write, enter the command
    mount -o remount,rw /
  9. If you have /home, /boot, /tmp, or any other mount point on a separate partition, you can mount them with the command
    mount --all (This must be done following step 8 so that /etc/mtab is writable.) Alternatively, you could try selecting "Enable networking" in step 7, though this has been found to cause the system to hang (see https://bugs.launchpad.net/ubuntu/+source/friendly-recovery/+bug/981792).
NOTE 1: If you have Ubuntu Quantal (12.10) or earlier, omit step 4 (the recovery mode menu items are displayed on the top-level menu).
NOTE 2: If you reboot, there is no need to hold the Shift key in step 3. The GNU GRUB menu will continue to be displayed automatically on each boot until a normal startup of Ubuntu completes. To configure GRUB so the menu is always displayed, even after a normal startup, see https://help.ubuntu.com/community/Grub2/Setup.
Oct 16, 2013 | Compaq Computers & Internet
I have installed Windows 7 and now audio is not working
Windows 7 is faily new in the Operating System world, and it's a 64 bit OS, while many drivers are not yet supporting 64 bit. Hopefully soon they will have better 64 bit driver support for windows. Myself personally I like to use Ubuntu which is based on the GNU/Linux distribution.
Have you checked your device manager for any problems there with your sound card problem?
Jan 02, 2010 | Asrock K7VM3 Motherboard
switch to linux
Boot off an ubuntu cd and see if everything works. Try plugging your printers in and printing test pages.
Jun 17, 2009 | PC Mall Ubuntu 8.10 for Linux
1,483 people viewed this tip
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
