Tip & How-To about Cell Phones
Tips and tricks for nokia phones
ON MAIN SCREEN: *#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This will clear the LCD display(operator logo). *#0000# To view software version.*#2820# Bluetooth device address. *#746025625# Sim clock allowed status. #pw+1234567890+1# Shows if sim have restrictions. *#92702689# - takes you to a secret menu where you may find some of the information below:1. Displays Serial Number.2. Displays the Month and Year of Manufacture3. Displays (if there) the date where the phone was purchased (MMYY)4. Displays the date of the last repair - if found (0000)5. Shows life timer of phone (time passes since last start) *#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restartIf you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345Press *#3925538# to delete the contents and code of wallet.Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# *#7328748263373738# resets security code.Default security code is 12345Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Cell Phones Logo
what is mean by imei
The International Mobile Equipment Identity or IMEI is a number, usually unique to identify GSM, WCDMA, and iDEN mobile phones, as well as some satellite phones. It is usually found printed inside the battery compartment of the phone. It can also be displayed on the screen of the phone by entering *#06# into the keypad on most phones.
May 04, 2011 | Nokia 1110i Cellular Phone
i want know about nokia6300 codes
These are the codes which will work on your device:
#06# for checking the IMEI (International Mobile Equipment Identity). #7780# reset to factory settings. #67705646# This will clear the LCD display(operator logo). #0000# To view software version. #2820# Bluetooth device address. #746025625# Sim clock allowed status.
Dec 31, 2010 | Nokia 6300 Cellular Phone
what is imei number?
The International Mobile Equipment Identity or IMEI (pronounced /aɪˈmiː/) is a number unique to every GSM and WCDMA and iDEN mobile phone, as well as some satellite phones. It is usually found printed inside the battery compartment of the phone. It can also be displayed on the screen of the phone by entering *#06# into the keypad.
May 29, 2009 | Nokia 1100
185 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
