Tip & How-To about Cameras
Panasonic LE15 digital camera - battery problem
If you have a problem that your camera keeps shutting down even with seeming good batteries, the cause may be due to one of the following:
1. the obvious is that the AA batteries are depleated and need renwal.
ensure you use high power or rechargable batteries and ensure they are fully charged as low power will cause the camera to shutdown.
2. check your flash memory installed on your camera, sometimes the memory may make a problem that causes the camera to shutdown with a battery or some other message. Try removing your flash memory and use your camera without it, to see if this is the problem. if it is a flash memory problem, remove and save any wanted data from the flashcard and then format it, by right clicking on it when inserted in your computer card reader and pressing format, (admin rights needed on windows) after this, re-insert the card back in the camera and test.
3. if batteries are not high power such as alakaline or carbon batteries the camera will shut down stateing that you should use high power batteries.
most digital camera with foldaway lenses will shut down while still having some power left in the battery this is to ensure that the lens and data is stored properly to avoid damage.
Cameras Logo
Why does my camera keep shutting down on its own?
It shuts down either of the following reason 1) Battery has corrupted or stop working 2) firmware has been corrupted 3) there is a mechanical displacement due to which to avoid further damage it shuts off.
Jun 15, 2010 | Olympus FE-360 Digital Camera
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
93 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
