Tip & How-To about Garmin nuvi 885T GPS Receiver
How to Perform a Hard Reset of your Garmin Nuvi 885T
Does your Garmin Nuvi 885T Freeze at Loading Maps?
Does it lock up or stop working?
There are two solutions to this problem; sometimes either one fixes all problematic symptoms and sometimes they need to be used in tandem.
My previous Garmin Nuvi 885T tip explained how to install new software into the device and where to get the software from. This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 885T.
I hope that helps.
_____________________________________
Garmin Nuvi 885T Firmware Download
Download Nuvi 885T Manual
Change Nuvi 885T Language
Garmin nuvi 885T GPS Receiver Logo
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
stuck on loading maps
Egypt Maps for all Garmin GPS
www.a100100.com
waleed hagag
+2 010 0002506
Jan 12, 2010 | Garmin nuvi 350 GPS Receiver
it will not load the maps..difficulty in going beyond this. It is "frozen" in prior location & says "loading satellite" (or something similar) and never changes. Last trip of 45 min it was like this the entire time. The battery was just charged Thanks Dolly Howard
There are two solutions to get your Garmin Nuvi 885T running smoothly again. I have posted detailed directions in the Tips section of this Fixya website. Follow these two links to find step by step instructions on how to perform both the hard reset and the software upgrade.
I hope that helps.
Nov 25, 2009 | Garmin nuvi 885T GPS Receiver
my screen stop at "loading map"
I hope that helps.
Nov 18, 2009 | Garmin nuvi 885T GPS Receiver
4,261 people viewed this tip
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
