Tip & How-To about Nintendo DS Lite Console
My DS has power, but my screens are blank!
HELLO!!
I've seen countless amounts of Nintendo DSlites with this generic problem. If you have experience opening up electronics, you will find this to be a VERY easy fix. A fix that'll make you happy you didn't blow money on having a professional repair it. It doesn't take a professional to repair this. Continue reading :)
PROBLEM: A Nintedo DSLite that powers up, but doesn't display video. Here's what your situation should look like
  1. Nintendo DS has power. (power indicator light is either green or red.)
  2. Both screens (upper and lower) are both black/blank
What causes this problem?
- Your Wireless wifi board on your nintendo DS has gone bad.
How do we fix this problem?
- Simple, replace it :)
Here's what it looks like...
This is where it goes... (top left corner)
Easy Easy Fix...
If it helps, please let me know!
Great!
Nintendo DS Lite Console Logo
where do I locate horn on jeep cherokee
in the front.
use a thing called a flash light,
an you will see it.
assumes you;ve seen others., have you>?
or are clueless.?
the FSM cover this
want to read the real book?
its free.
ZJ JEEP, 1996 IT IS
CLICK ZJ
CLICK HORN SYSTEM.
posted over 100 times now.... countless.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
all cars have a book like this, and anyone can buy it read it or login at mitchells and read it. cheap.
anyone.
Dec 27, 2015 | 1996 Jeep Grand Cherokee
RightClick Open-With
Go to Properties of any application select too many times its default open application the n it will show.
Jun 07, 2013 | Computers & Internet
No DS card inserted and There is no gamepak inserted error messages on Nintendo DS
Problem Solved: Look into the socket where the cartridge is inserted and count the number of pins you see.
If it is less than 17, then you have a contact pin that has broken off or is bent to the point it can no longer be seen and is not making contact with the cartridge.
If you have warranty, take it back and have them replace the unit, if you don't have warranty you have to take the unit apart and replace the socket yourself. (WARRNING) if you have no experience with soldering, do not attempt this!
I have 30+ years in electronics and have taken these units apart, and have always found pins missing or bent over to the point of not making contact.
Hope this helps!
Jun 18, 2009 | Nintendo DS Lite Console
tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
VGN-TX850P/B Display Problem
Hello Frank,
This is Romeet, id like to try and help you.Most Sony's have a small circuit at the front end of the LCD that effectively works like an Inverter Circuit.How good are you at opening these things up? any electronic repair centre near you? has to be a problem with the fusible resistor or inductor on the circuit i mentioned ( as mostly seen in my experience ).Please let me know.
B.Regds
Romeet
Dec 01, 2007 | Sony VAIO VGN-TX850P/B PC Notebook
1,024 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
