Tip & How-To about Nintendo DS Lite Console
When your screens blink.. What to do!
A lot of people have had the dreadful blinking of the screens. Whether it's only 1 screen blinking (upper or lower) , or both screens blinking..
I have a tip to help you diagnose the problem so you don't have to waste time trying to find out what's wrong with it, or waste money.
1.) IF YOUR UPPER LCD BLINKS
  • There is something wrong with your lower LCD and/or the connector on the board where the lower lcd connects to.
POTENTIAL SOLUTION
  • Open up your Nintendo DS lite system and clean the board with rubbing alcohol. Be sure to dry the board from excess liquid before re-assembling it. Use a FIRM brush. An regular toothbrush would not work as the bristles are not firm enough.
2.) IF YOUR LOWER LCD BLINKS
  • There is something wrong with your upper LCD and/or the connector on the board where the upper lcd connects to.
  • Follow the Potential Solution to #1
3.) IF BOTH SCREENS BLINK
  • 99.9% of the time, if both screens blink, your light is red. Which indicates your battery is low. Change the battery. If your system isn't charing your batteries correctly and/or you're losing battery power unusually quick, replace the charger.
  • If that does not work, send your system in for repair, as the charging port needs to be cleaned.
Nintendo DS Lite Console Logo
MY HITACHI SCREEN IS BLACK, POWER ON BLUE LIGHT BLINKS 4 TIMES
sounds like bad mainboard or power supply board most likely the power supply
Jan 30, 2013 | Hitachi Televison & Video
When i swithch off my Phillips Tv model 25PT4323/79R when the picture appear it switch off after 10 seconds which unit on the board needs to be replaced
Hello
It may be due to the change [high] in the screen voltage. You just open your tv and locate the screen control. You cn see it attached with the LOT [Line Output Transformer]. There are two controls integrated to it and are adjustable. Out of which, one is for facus adjustment, and the other is for screen adjustment. Usually the upper one is meant for focus adjust, and the lower one for screen adjustment, and there will be visible markings near it about which is it meant for. Just turn it counterclokwise a little, say very little, while the tv is on and there is screen on it, whether it is blue back or grains. More turn counterclockwise will make the picture in your tv get smeared. A little must be done.
Check this and see. Ok
Nov 19, 2010 | Philips Magnavox MWC20T6 TV
dreaded 4 blinks
Tries take out ur video connection to ur board. See if u get the power to the to the tv.If u still getting power but blinking ur power board it dead.U just hope not ur backlight,if it is u in major trouble very expense only professional have the equipment to replace the backlight must have recalabration gun to fix this prob.Power board prob. only $300 u do the the labors,if tv tech. do it well cost u $575 but u have 1 year waranty.U who know??
Aug 24, 2009 | Televison & Video
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
811 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
