Tip & How-To about Cell Phones
Does Your Phone Have Water Damage?
((If this is about a device other than a phone, like an iPod, camera, GPS, etc... skip to the bottom))
While working at Radio Shack, I picked up this handy trick.
I know it sounds crazy, but...
Remove the back of the phone, battery, and SIM (if your phone uses one) - IMMEDIATELY.
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). I know it sounds silly, but it draws the moisture out.
It normally is working after just 5-6 hours, but I would wait overnight or even a full day before attempting to use (just to be on the safe side).
BEWARE - the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be EXTRA careful.
Hope this helps. :)
ALSO - This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
Cell Phones Logo
how do you download an update with no usb
In most cases Garmin requires for the device to be plugged in, you have to use Garmin Express. Found here....
Garmin Express
The USB cable can be bought for cheap at any computer store, Radio Shack, Best Buy, etc etc.
Aug 13, 2014 | Garmin Nuvi 1300 GPS Receiver
Two years old..Will not turn on when plugged in
Radio Shack have a Device sort of an adapter that works great with it , also u need to check on the car/truck fuse or just simple get a new adapter from radio shack
Sep 22, 2011 | Garmin Nuvi 660 GPS Receiver
my cord to my motorola TN20 has come apart (one wire came out of the end). is it possible to have this repaired or purchase a new cord? if so, how do i get it repaired or where do i purchase a new cord?
Any standard USB cord or charger will work. You can plug it into your computer for charging if you have a camera cord. You will get a warning about longer charge time but it works. Walmart, Radio Shack etc should have a cheap USB charger.
Nov 09, 2010 | Motorola Mobility MOTONAV TN20 GPS...
nuvi 255w-Where can I get a replacement fuse for the car powercharger? What is the fuse number?
On the plug charger unscrew the silver or black bottom tip of plug.. you can probably get a fuse from radio Shack or any Electrical supply store.
Oct 22, 2010 | Garmin Nuvi 660 GPS Receiver
I lost the usb cable for my Sanyo VPC-t1060. I've
Best Buy, Radio Shack, Walmart, etc. Take your camera with you to get the correct size.
Sep 25, 2009 | Sanyo VPC-T1060 Digital Camera
5,600 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
