Tip & How-To about Audio Players & Recorders
IPod Shuffle 2nd & 3rd gen Sync cable
Save up to $50, make a sync cable for ipod shuffle 2nd gen and 3rd gen on your own,
all you need is a 4 poles 3.5 mm jack, and USB plug. you get this on an old USB connectors ,
the color coding of USB cables is in standard so all you have to do is to solder the color coded wire to the 3.5 mm jack
here are the links of pictures of wire color coding that tells where the wire shouuld be solder http://i863.photobucket.com/albums/ab192/matrix_jc2001/Untitled-1.jpg
ipod shuffle 2nd gen problem
Remember these five basic suggestions if you have a problem with iPod shuffle. Try
these steps one at a time until the problem is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
Reset iPod shuffle by turning it off, waiting five seconds, and then turning it back on
again.
Retry with a different USB port if you cannot see iPod shuffle in iTunes.
Restart your computer, and make sure you have the latest software updates
installed.
 Reinstall iTunes software from the latest version on the web.
 If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
 Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
Turn iPod shuffle off, wait five seconds, and then turn it on again.
You may need to restore iPod shuffle software
May 31, 2009 | Apple iPod shuffle Second Gen. Silver (1...
ipod no longer syncs
It happened to me once.One problem is that you iPod's version is higher than your PC version(Or vis-versa).So just try updating you iPod and PC.
Apr 09, 2009 | Apple iPod shuffle Second Gen. Silver (1...
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
ipod shuffle 2 gen
You will need to plug the player into your TV, not the DVD player. also, don't connect to TV using USB cable (if your TV has a USB cable). Get a 2-1 adapter that has one end plugged into headphone jack, and the other end plugged into a red and white audio IN port on your TV. Set TV channel to that IN port (Video1, AV1, or whatever your TV is calling that IN port.
Jan 09, 2008 | Apple iPod shuffle Second Gen. Silver (1...
2,148 people viewed this tip
 Grubhead
Grubhead
