Tip & How-To about Computers & Internet
Booting a bootable Windows CD/DVD for a fresh installation when the boot order is failing
There have been several times that people have been stuck with a virus infected or a corrupt Windows Operating System and are finding it very difficult to get a fresh installation because of a boot order problem. It could also be a clean working Operating System but the user just wants a new one. The PC, whether laptop or desktop, could be a gift from a friend or one that they have been using for some time.
In the case of a gift from a friend, it could be that a forgotten password has been set in the bios and all has been done by the user to gain access but to no avail. There are also situations whereby the boot order is set alright to boot from CD/DVD but the PC just fails to boot from the CD. In these cases, even thought the bootable CD/DVD is in the drive, the PC just boots straight to the unwanted Operating System but you know that your CD/DVD drive works fine.
Here's what to do:
Obtain appropriate screw drivers and carefully remove the hard disk from the laptop or desktop. Now Obtain an appropriate external hard disk connector for the type of hard drive you have. In the case of a desktop hard disk, you could easily connect it as a slave hard drive in another available desktop by setting the jumper to the slave position (could be primary slave or secondary slave depending on the drives in the PC).
Try and backup any important files from the hard disk or from the partition with the Operation System in the case where more than one partition exists on the hard drive. When that is done, then you will need a Hard Disk or Partition Management Software like Windows Disk Management(which can be accessed by right-clicking on 'My Computer' and selecting 'Manage' and the 'Disk Management' in the resulting window). You can also use a third party software.
Now delete the partition and create a new Partition (Primary Partition). Then format the partition (NTFS file system recommended). When this is done, disconnect the hard disk and fix it back into the PC. Now you are ready to install a fresh Windows Operation System. Turn on the PC, Insert the bootable Operating System CD/DVD (e.g Windows XP) and there you go: your PC will automatically boot from the CD/DVD.
Wish you all the best.
Computers & Internet Logo
shut down
Possible corrupt operating system. The cause of corrupt operating system is Windows file corrupted or virus infected Windows.
Solution corrupt Windows files:
1. START - All Programs - Accessories - System Tools - System Recovery Options - System Restore (restore to the date when the OS is still normal)
2. START - All Programs - Accessories - System Tools - System Recovery Options - System Image Recovery (restore using a backup system that you created)
Solution files corrupted due to virus infected windows
Update anti-virus and virus scan (if the virus is detected, the primary action = repair, secondary action = quarantine). Then repair the operating system with System Restore or System Recovery Options.
Note:
If the operating system infected with virus (virus infected not long ago), the best solution is to use System Restore. Restore to a date when the windows are still normal.
Nov 13, 2011 | Toshiba Computers & Internet
my computer is unable to boot in any of the options, what do i do?
Booting problems with your laptop occur when the computer gets infected by a virus or when there are underlying hardware problems.You can use several troubleshooting techniques before taking the laptop to a service center for repair.
1. Turn on the laptop without pressing the power button too long, to prevent it from turning on and then turning off. Also make sure that the laptop has enough battery power to boot up.
2. Unplug any external drives connected to the computer. These include flash drives, external hard drives or any CD or DVD in the optical drive. Listen closely as you boot the computer. If the laptop is emitting ticking sounds and refuses to boot up at all, the hard drive or another internal component may be damaged. Consider bringing your laptop to a service center.
3. Turn on your computer and boot to "Safe Mode" or "Last known good configuration" if the computer powers on but displays an error before it boots the operating system. If this is the case, the laptop may be infected with a virus.
4. Use the "System Restore" feature in Windows to restore the operating system to an earlier time. Note, however, that this will not work for those whose computers have the "System Restore" feature disabled. Click "Start," "All Programs," "Accessories," "System Tools," and then "System Restore." When the dialog box appears, click on the box for "Restore my computer to an earlier time," and then "Next." Select the restore point that you want and follow further instructions.
5. Resolve a "blue screen" problem. This error screen appears before booting, and is caused by several factors such as virus infection or hardware failure. Read the error message to determine what factor caused the problem. The error message should include troubleshooting tips.
6. Consider repairing the operating system if the computer does not boot at all. This procedure will repair the operating system without erasing your data and settings. Access the Resource list for instructions on how to repair Windows.
I hope you find it very helpful. Thank you for using fixya.
Aug 15, 2011 | Computers & Internet
Operating System not found. Any ideas ?
Exactly what it says there is no windows left in your netbook - you had a severe virus infection that has corrupted it completely. You will have to reinstall it. For that you will need an external CD unit and the recovery cd. If you don't have it you will have to order it directly from Samsung.
Apr 06, 2011 | Samsung NF210-A02 Netbook
Have to click on items several times to get it to work then it gets stuck on
Hello and Welcome to FixYa!
It seems that you need to re-install/run recovery on your system. Your system is overloaded with softwares and applications or the operating system files are getting corrupt due to virus/threats infections.... Restore your system or run the recovery to get rid of the trouble...you are facing....
Best of Luck,
Please do RATE the solution, if found Helpful,
Concerned.
Jul 05, 2010 | Computers & Internet
My computer infected by viruses
well i think the virus has badly infected your system so u have no other option then to format it.
Apr 08, 2009 | Microsoft Windows XP Professional for PC
245 people viewed this tip
David Payne
David Payne
