Tip & How-To about Cell Phones
Why your sony phones get problem of turn on and turn off it self ?
Sony Ericsson phones always get this problem like some times phone screen blinks,switch off and on itself. it happens when your phone get any liquid damage,and when you could not complete the update process of your phone. Firstly if your phone get liquid damage so quickly switch it off and take out the battery try to wipe liquid.. ( please do not use hot dryer) hot dryer always gives some short circuit on mother board. If you do updating of your phone and you could not complete updating then it get this problem like not turning on and screen blinks.for solving this problem you need Sony Ericsson software tool box and two software files If you have that tool. then connect with PC and LAPTOP and install it. when is fully installed it shows icon on desktop double click on that and it gives you window. On window see left hand side top some option like S.E ,A-1 ,A-2 .firstly click on first option and select model if you couldnt find then second and third option.mostly Sony Ericsson series K means K800, K850 in first option and W series and C series like C 902 ,C905 in A1 select model and see left bottom of the window select mode USB ( do not select COM or UFS ) then right hand side top last option IDENTIFY click on that.your phone should be switch off with fully charged battery then do what ever window said like if you click on IDENTIFY so it says connect your USB while pressing C or some times it says connect your USB while hold 2+5. when it shows phone detected then disconnect USB FROM THE PHONE. take out battery and put it back. see what ever information it given you like then model number and in RED word you will see CID. like CID 49 .CID 51 AND 52 AND 53. and in information you will get the software file shows like RE100EDre1d001w1d1001 just see which is the software file your phone has then connect your internet and GO SUPPORT YOU CAN FIND THIS OPTION IN MIDDLE BOTTOM . it goes directly Online on this software tolls side and select sony ericsson then select model and select CID THEN YOU WILL see some files firstly check your phone file and find same number file in GENERIC then down load it and save in desk top.and fine same file in European file ( make sure second FILE is your LANGUAGE FILE which gives you the phone language) down load it and save same place when down load complete then go to software window and see under the secet model option you will find small window and that right hand side see some option like add file, remove file and clear .Click on add files it gives you your pc or laptop window go to Desk top and add that file which are you down loaded from On line. make sure GENERIC FILE ALWAYS ADD FIRST THEN SECOND FILE. when you added file. Go to setting this option you can see on top in software window select on two option which first one 1- singed mode ( signed mode always first option ) you need to tick only.2- complete phone after flash / customise phone after flash ( this option could be 4 or 5 ) then go back to via clicking on model option then right hand side where you did IDENTIFY second option flash click on that. then do what ever it says like connect usb to your phone while pressing C button or while PRESSING 2+5. then wait for complete this process.it takes 7 to 12 minutes time then when it show you phone detected. disconnect the phone and take out the battery and put back turn on your phone and wait. Your phone will show wait sign on screen then your phone will be OK
USE YOUR SONY ERICSSON PHONE HAPPILY
Thanks
Regards
Tony Singh
Cell Phones Logo
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
screen blinking when i switch on my phone K750i
the Memory Stick might be corrupted, that is why ur phone behaves like this. try formatting ur memory Stick and then use it
Mar 21, 2009 | Sony Ericsson K750i Cellular Phone
white screen
Hi - i know this problem I have had many sony ericsson models, and somehow always 1 of 2 issues -
1) your memory card is corrupt or has a bad file
2) you recently dropeed the phone, and an issue on the board like hairline crack - so contacts arent 100% connected for the power / data transfer from board to screen
3) you recently dropped the phone, and have internal FLEX cable tear
We do offer the FIX for whitescreen - if you want to send we can take a look
thans
http://www.horizonwirelessonline.com/cat/index.php?main_page=product_info&products_id=185&zenid=e9a5d3866a45ea05b101ead4f8ae4da6
Jun 11, 2008 | Sony Ericsson K800i Cellular Phone
i want to format my sony ericsson k700i phone.
you could try to do a master reset with in the settings menu on your phone to it original state.
riz
Feb 04, 2008 | Sony Ericsson K700i Cellular Phone
111 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
