Tip & How-To about Computers & Internet
Follow the following steps
* Open notepad.exe, type "del c:\windows\prefetch\ntosboot-*.* /q" (without the quotes) and save as "ntosboot.bat in c:\
* From the Start menu, select "Run..." & type gpedit,msc".
* Double Click "Windows Settings" under "Computer Configuration" and double click again on "Shutdown" in the right window.
* In the new window, click "add", "Browse", locate your "ntosboot.bat" file & click "Open".
* Click "OK", "Apply" & "OK" once again to exit,
* From the Start menu, select "Run..." & type "devmgmt.msc".
* Double Click on "IDE ATA/ATAPI controllers"
* Right Click on "Primary IDE Channel" and select "Properties".
* Select the "Advanced Settings" tab then on the device or 1 that doesn't have 'device type' greyed out select 'none' instead of 'autodetect' & click "OK".
*Right Click on "Secondary IDE Channel", select "Properties" and repeat step 9.
*Reboot your computer.
