Tip & How-To about Computers & Internet
How to enter Factory settings on GNR TS700 (Black/Silver) 17" LCD monitor
- Press Power to turn screen off
- Press and hold Select/Auto
- Press Power to turn screen on. LED will be Orange instead of Green
- Release Select/Auto
- Press Menu
- You will see 2 additional options (Factory 1 & Factory 2)
- Exit as normal
- To return LED to Green, Power off then Power on
To reset colour:
- Choose Factory 2
- Choose Auto Color1
Computers & Internet Logo
lg e700sh monitor out of shape i need the settings of original shape
try factory settings
- Press Menu
- Exit as normal
To reset colour:
- Choose Factory 2
Jun 14, 2011 | LG Flatron F700B 17" CRT Monitor
how do i reset my pixma 1990 printer the ink receptacle is full message keeps on appearing?
To reset the printer follow these steps : 1. Turn off the printer and hold the "RESUME" button located on top of the MP220. While holding the "RESUME" button, press the "POWER" button and wait for the machine's green LED to illuminate.
2. Release the "RESUME" button while holding the "POWER" button. Press the "RESUME" button twice and release the "POWER" button.
3. Press the "RESUME" button four times followed by the "POWER" button. Turn the printer off and then on to complete the reset process.
As per your error follow the below mentioned steps :
1. Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2. While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3. While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5. Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6. Power off then check it.
In case if the problem persists please revert back.
May 22, 2011 | Office Equipment & Supplies
how to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
i need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
canon i900d wast ink tank - how to reset it ? Please reply at sunil@honeyblue.com
The following procedure is from the Canon i900D Maintenance Manual:
1. With the printer power turned off, while pressing the Resume button, press and hold the Power button. (Do not release the buttons. Wait for the LED to light green, which means you can select a function.)
2. While holding the Power button, release the Resume button. (Do not release the Power button.)
3. While holding the Power button, press the Resume 2 times. On the first press, the LED lights orange; on the second press, it turns green. Release the Power and Resume buttons.
4. The LED light should be green. Press the Resume button four times. Each time you press the Resume button, the LED lights first orange and then green.
5. The LED light should be green and the printer should now reset the waste ink counter. When the operation completes, the printer returns to the menu selection mode automatically.
Apr 12, 2008 | Canon I900D InkJet Photo Printer
3,862 people viewed this tip
David Payne
David Payne
