Tip & How-To about GPS
How To Replace Your Garmin Nuvi 750 Battery
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
From NewPower99.com, this video provides a step by step demonstration of the procedure for replacing the battery in your Garmin Nuvi 750 GPS. The battery, along with the necessary installation tools shown in the video, can be found at: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
GPS Logo
the 670 garmin shut down then say's low battery
musicman340,
It sounds like the rechargeable battery inside your gps is coming to the end of its life. After enduring the temperature extremes of your car in addition to numerous charges and discharges, these batteries do eventually die after a couple years. How old is your nuvi? If this is the problem, the good news is that you don't have to throw your gps away as this battery is readily replaceable if you follow the steps in this video:
The company that produced the video sells a kit which includes the battery and tools necessary to replace your battery. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+670&Show=ExtInfo
I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi is back up and running smoothly.
Mar 15, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin 680 doesn't seem to hold a charge. How do I replace the battery?
Replacing the nuvi 680's battery is actually not all that hard as this video demonstrates:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+680&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi 680 is back up and running smoothly.
Jan 11, 2010 | Garmin Nuvi 680 GPS Receiver
garmin nuvi 750 battery does not hold a charge
A new battery can be purchased and installed inexpensively. I found a video.
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
My GPS Garmin 750 battery isnt holding a charge much any more. The warantee is already past. We just need a new battery ... what do you suggest?
The battery is replaceable. Batteryship.com sells a battery for around 27 or 28 dollars and a 7 dollar kit. There are two small torq screws that can be removed with the screw driver provided in the kit. The plastic tool provided in the kit is used to pry open the the back cover after the two screws are removed. removing the cover takes some force after you can get your fingers in to pull it apart. Once the cover comes loose remove the wires attached to the Garmin from the battery and the speaker. Notice how the small plastic ends fit in from the battery and the speaker to make certain that the small ends go in correctly. The battery is secured with a sticky tape and has to be muscled out of the unit. The new battery can be secured with double sticky back tape or some of the saved tape from the old battery. Secure the back and replace the small screws and your in business. The battery requires charging. Good luck it worked for me and I'm an all thumbs guy
Dec 19, 2008 | GPS
110 people viewed this tip
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
