Tip & How-To about Heating & Cooling
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
Heating & Cooling Logo
The furnace will start and run for 5 mins and kick off. Then the burners will not reignite after that. However, after everything cools down (about a half and hour later) it will restart and run for another 5 mins and then I have the same problem all over again. What is my problem?
Hello, sounds Like the Furnace is tuning off due to the limit switch or rollout switch opening. A limit switch and rollout switch are safety swtiches that will turn off the furnace if it gets to hot or the burners flames are abnormal. Usually a weak blower motor, dirty blower wheel , dirty burners or even a crack in the heat exchanger can cause this problem. Best bet is to call a hvac technician and have them check it out.
Sep 14, 2011 | Heating & Cooling
We have a White-Rodgers 1F80-51. The fan blows
May 31, 2010 | Heating & Cooling
tappan furnace blower will not shut off and furnace does not heat and red light is blinking one flash constantly.
Mar 12, 2010 | Heating & Cooling
Outside heating unit runs all the time
Feb 19, 2010 | Heating & Cooling
furnace blower won't stop running
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
591 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
