Tip & How-To about Canon imageCLASS D320 All-In-One Laser Printer
How to get rid of faint copies
The most common problem that people have with this printer is that they say that the copies are faint. It could be that your toner is out of ink so make sure that the computer software and the printers display is not saying that you have to replace the toner. If it doesn't then its probably that the toner saver mode is on. to change it go to Additional Functions> Common Settings> Toner Saver Mode and change it to off. It should solve your problem . Thank you.
Canon imageCLASS D320 All-In-One Laser Printer Logo
Machine is printing faint copy what could be possible error
Try doing an ink head clean. If you give me the make/model I'll tell you how to do that.
Dec 14, 2016 | Office Equipment & Supplies
Faint printing
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Mar 24, 2014 | Brother MFC-7440N Multifunction Network...
ink on left hand side of page very faint
First make sure that the print cartridge has enough toner. If the toner is OK, it is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the printer, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Apr 07, 2011 | Dell 2130cn Laser Printer
Faint copies, despite new cartridge.
Go to Additional Functions> Common Settings> Toner Saver Mode and make sure its off.
Sep 27, 2009 | Canon imageCLASS D320 Digital Copier
2,598 people viewed this tip
old marine
old marine
