Tip & How-To about Heating & Cooling
How to store you air conditioner for the winter?
Make sure that you tip the A/C unit to remove water that has condensed in it. If water is left in the system over the winter/spring, it can rust out the evaporators in the A/C and cause problems with its functioning. Also, the water can serve as a breeding ground for mold and bacteria.
Heating & Cooling Logo
Need an undercarriage protection for our 2003 chevy blazer - cant find one!
There are any number of commercial protection products available over the counter.. of any auto part store, or online.
In my own humble opinion... Your best protection is regular washing with clean water, and some WD40 on all unpainted surfaces. Any coating you put on will eventually trap moisture and contaminants under it, causing corrosion faster.
Easy way to prevent undercarriage rust is to power wash the entire undercarrage, then spray the entire undercarriage with WD-40 before the onset of winter.
WD-40 displaces water, helping to keep rust under control. Suprisingly, it doesn't come off as easily as you'd think in wet winter driving.
Use use two medium size cans of WD-40 to do all undercarriage, making sure to spray every nook and cranny (but avoiding the brake rotors/pads) until it is saturated.
Believe it or not, one good coating will last all winter--at least enough to prevent rust. Each spring, use a high pressure sprayer to clean the undercarriage and reapply a new coat of WD-40 for the spring/summer/fall months.
Jan 09, 2011 | 2003 Chevrolet Blazer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
What do I have to do to winterize my pressure washer? It will be in an unheated shed all winter.
Gasoline goes bad after sitting for an extended period of time.
Old school people would drain the gas out of the tank but found this lead to rust forming in the tank.
Now it is best to fill the tank with high octane gas and use a winterizing fuel additive to prevent problems.
Also remove any water from the hoses.
In the spring replace the gas and change the oil and you should be good, changing the spark plug would also be beneficial.
Oct 10, 2009 | Northstar Pressure Washer 2800 PSI
Miele T358C dryer. water not being pumped out of the sump??
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
140 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
