Tip & How-To about Vehicle Parts & Accessories
Well if you have a old laptop with a broken hinge or if its just old and you dont have a use for it. Before you trash it, make it into a digital picture frame, supplies needed: Plexi-glass old laptop with good screen screws, nuts, bolts, tools, dremel, what ever you decide to use a little knowledge of computer parts a usb extension cord for making the usb port on the side a power jack for charging perferably a disk drive harddrive (which should be in the laptop wifi card (optional) - wifi antennas power cord usb keyboard mouse combo (perferably one that only requires 1 usb adapter, otherwise you will need a usb hub) simply, dissassemble the unit, add a usb receiver for a keyboard mouse combo, mount the parts(motherboard, screen, drive, harddrive, ram, heatsink, processor, fan, wifi card(optional) usb reciever for keyboard mouse combo, SCREEN INVERTER (OR UR SCREEN WILL BE DARK),etc, speakers) into a pelxi glass box which is easy to make, add some vents on the side for the fan, also add a usb port and a charger port, and a simple stand and you got a digital picture frame, you may also want to add a disk drive onto it. also good for playing dvds, internet (if u install a wifi card), music (if there are speakers in the laptop, install them into this), and much more! also have fun with it, dont worry about breaking it, its a laptop you were going to trash anyways, just have fun with it to add the power jack just plug a similar end into the port on the motherboard and connect a jack that fits the charger on the end and mount it (hot glue works) on the back out of the way, or on the side. operating system info also if it is a pre-2000 computer, then install the windows operating system, if its later then 2000 then you may want to install something called Ubuntu, its a linux distro, very handy, and its absoultly free, you can order a free disk with free shipping here https://shipit.ubuntu.com/ terms: motherboard: the central board where everything connects: http://www.laptopparts101.com/wp-content/uploads/2008/12/laptop-main-board-560x420.jpg ram: Random Access memory, the temporary data storage medium, when you turn off the computer this memory is dumped, but you dont loose any files because there on the harddrive (see harddrive): http://www.amitbhawani.com/blog/Images/L/Laptop-Ram.jpg Lcd Display: Liquid crystal Display, the screen: http://www.made-in-china.com/image/2f0j00SvwtJoganrbPM/LCD-Panel-LTM240M2-L01-.jpg screen inverter: a device in the screen region that ups the voltage to what is required for the ccfl to light: http://media.photobucket.com/image/Lcd%20panel%20inverter/davidli919/inverter.jpg ccfl: a cold cathode floresent light, similar to normal flouresent lights just smaller: http://www.byfort.com/ccfl/LCDCCFL.jpg cpu: the part in a computer that processes everything that happens on the computer: http://img.alibaba.com/photo/104768066/Laptop_cpu_various_P8400_P9500_T5450_T5750_CENTRINO_1_7_2_0_ETC.jpg Operating System, the software that makes everything possible on the computer, without a Operating System (aka O.S. or os) all your computer will do is sit at a black screen and say no operating system found.: http://img279.imageshack.us/i/100120062323kp.jpg/ Disk Drive: a drive capable of reading discs: http://images.google.com/imgres?imgurl=http://www.laptopparts101.com/wp-content/uploads/2008/12/laptop-cd-dvd-optical-drives.jpg&imgrefurl=http://www.laptopparts101.com/cd-dvd-optical-drive/&usg=__Ux6rSxMNgmluei_j6e7oRXf9N0I=&h=420&w=560&sz=38&hl=en&start=1&sig2=RyGhHxAr5xAdTtaS7oJcAA&tbnid=c63UleTeaakrTM:&tbnh=100&tbnw=133&prev=/images%3Fq%3Dlaptop%2Bopticak%2Bdisk%2Bdrive%26gbv%3D2%26hl%3Den%26sa%3DG&ei=GJ87S7TUApDktAOR9JSZBA harddrive: a device that stores all the info including the operating system, this does not get wiped when the computer loses battery or gets turned off.: http://img.alibaba.com/photo/215581192/2_5_160gb_IDE_hard_disk_drive_160gb_IDE_HDD_.jpg
Vehicle Parts & Accessories Logo
The left hand hinge cover has broken..can I get a replacement?
You will have to return the laptop to where you bought it and tell them what you want done. They will send it off to the manufactuer and replace the broken hinge, but you may be charged a small fee.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Samsung N13013B Netbook
MY left IBM Thinkpad Monitor hinge is broken what should
get a new hinge but dont do it yourself unless you know what you are doing, its only cause of the wiring and it being the screen will have to come out if it is the hinge inside you are talking about, cheers
Dec 12, 2009 | Cameras
broken hinge
I'd be frustrated as well. Fortunately, your Inspiron is still under warranty - contact Dell. They may send a tech to fix, or you may need to send back the laptop to them to be fixed.
Jul 30, 2009 | Dell Inspiron 1525 Notebook
Broken Laptop hinges
I had the same issue with my X72. The hinges of a Advent qrc430 will fit this model, As will most other parts off the advent.
Regards Mike
Apr 15, 2009 | Computers & Internet
Problem with hinges
Really no need to replace the laptop for this problem. Usually you can contact the manufacturer and they will be happy to sell you new hinges. Depending on the manufacturer and how the hinges are will determine the price. If you find them too pricey, go to ebay and look for hinges for your laptop model number. Chances are they'll be under $50.
Jun 09, 2007 | Balance CN6555 Notebook
219 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
