Tip & How-To about Coby MP-705 Digital Media Player
Coby MP-705: Adding music, film, data - Macintosh OS X
Macintosh OS X
Open a finder window. Located the files you would like to transfer from your computer.
Select the files/folders with the mouse and press APPLE-C (copy) on the keyboard.
Click on the Removable Disk icon located on the left side of the finder window.
The computer will display all files and folders currently stored in the player.
Press APPLE-V (paste) on the keyboard to transfer the files you selected in Step 1 to the player.
Coby MP-705  Digital Media Player  Logo
how to transfer photos from assurance android to computer?
hi Evelyn.
Move files by USB
  1. Unlock your Android device.
  2. With a USB cable, connect your device to your computer.
  3. On your device, tap the "USB for..." notification.
  4. Select Transfer files.
  5. A file transfer window will open on your computer. Use it to drag files.
  6. When you're done, eject your device from Windows.
  7. Unplug the USB cable.
Transfer files between your computer Android device
How to Transfer Photos from Android to Computer
Using Google Photos
  1. 1 . If it isn't, tap the switch to turn on backup for your photos. This will ensure that your Android's photos are uploaded to Google Photos.
  2. 6https://photos.google.com/. This will open a page with your Android's photos if they are backed up.
    • As with your Android, you may have to sign into your Google account with your email address and password if this is your first time opening Google Photos.
  3. 7[1]
  4. 2 . Click the Windows logo in the bottom-left corner of the screen.
  5. 3 . Click the folder-shaped icon in the lower-left side of the Start window. This will open the File Explorer program.
  6. 4http://www.android.com/filetransfer/. This will open the download page.
  7. 4 in the top-right corner of the screen, type in android file transfer, and then click the Android File Transfer icon.
  8. 7Double-click the "Internal storage" or "SD card" folder. Depending on where the photos you want to transfer are stored and what kind of storage is available on your Android, the folder you open may vary.
  9. 8
    Double-click the "DCIM" folder. This will open to another folder.
  10. 9
    Double-click the "Camera" folder. It's where your Android's photos are stored. Doing so will bring up a list of your Android's photos.
    • Depending on whether or not your photos are in an album, you may have to open another folder before continuing.
  11. 10
    Select your Android's photos. Click and drag your mouse across the photos you want to move onto your computer to select them. You can also hold down the ? Command key while clicking individual photos to select them independently.
  12. 11
    Click Edit. This menu item is in the upper-left side of your Mac's screen. A drop-down menu will appear.
  13. 12
    Click Copy. It's near the top of the Edit menu. This will copy your selected photos.
    • If you want to remove the files from your Android while transferring them to your Mac, click Cut here instead.
  14. 13
    Open Finder. Click the blue, face-like app in your Mac's Dock. A new window will open.
  15. 14
    Select a save location. Click a folder (e.g., All My Files) on the left side of the Finder window to select it as your photos' destination.
  16. 15
    Click Edit, then click Paste Items. This will copy the photos from your Android onto your Mac.
    • If you selected the Cut option instead of Copy, this will also remove the photos from your Android.
https://www.wikihow.tech/Transfer-Photos-from-Android-to-Computer
Dec 10, 2017 | Android Cell Phones
how do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
how do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
1,267 people viewed this tip
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
