Tip & How-To about Computers & Internet
What will be a perfect password?
Myth: if it is encrypted, it is secure.
Truth: if it is not encrypted, it is not secure.
Before creating a password you should know:
NO password is uncrackable.
The best you can do is making it difficult and non-trivial to determine your password.What's the worst password? The one you've forgotten.
Password recovery is the most difficult process, sometimes even is impossible.
Whatever method you choose, it's a good idea to change your password often.
The more important the password, the more often it should be changed.
Why? If someone is attempting a brute-force attack on your password, the hope is that you're changing it to something they've already tried and found to be wrong.
⑶The longer the password, the harder it is to 'guess.'
Note: many systems limit passwords to 8 characters.
Some clever people are foregoing brute-force hacks (e.g. dictionary attacks), in favor of 'social engineering' to obtain passwords.
If somebody calls or emails, requesting your password, it's a dumb idea to give it to them.
Of course nobody would sticky-note a password to their monitor, or under a keyboard. A good password is one that's hard to guess, yet easy to remember.
So here are the 6 steps to build a strong password related to you but look no relation.
It also used to avoid common password strategies that fail .
The strongest passwords look like a random string of characters to attackers. It will be perfect if it begins with a letter and mixes with capital letters and small letters and numbers and special characters.
Let’s try to make strong 6 characters password.
1. Think of something that you really want.
Example: "I want 1 million dollars."
2. Turn your sentence into a password.
try character encoding scheme in this case: "iw1m$".
3. Add complexity to your password or pass phrase Mix uppercase and lowercase letters and numbers.
Introduce intentional misspellings. For example, in the sentence above, you might substitute the letter i for the word "I", so a password might be "Iw1m$".
4. Substitute some special characters
Use symbols that look like letters, combine words, or replace letters with numbers to make the password complex. You see, 1=1.0. Using these strategies, you might end up with the password "Iw1.m$"
5. Test your new password with Password Checker
Password Checker evaluates your password's strength as you type.
6. Keep your password a secret
Treat your passwords with as much care as the information that they protect.
Qualities of strong passwords
Password Length
Each character you add to your password increases the protection it provides.
8 or more characters are the minimum for a strong password;
14 characters or longer are ideal.
Password Complexity
The greater variety of characters that you have in your password, the harder it is to guess.
An ideal password combines both length and different types of symbols.
Use the entire keyboard. Easy to remember, hard to guess The easiest way to remember your passwords is to write them down. It is OK to write passwords down, but keep them secret so they remain secure and effective.
Note:
Avoid sequences or repeated characters
"12345678," "222222," "abcdefg," or adjacent letters on your keyboard do not make secure passwords.
Avoid using only look-alike substitutions of numbers or symbols
Criminals will not be fooled by common look-alike replacements, such as to replace an 'i' with a '1' or an 'a' with '@' as in "M1cr0$0ft" or "P@ssw0rd".
Avoid your login name
don’t use any part of your name, birthday, social security number, or similar information for your loved ones. This type of information is one of the first things criminals will try, and they can find it easily online from social networking sites, online resumes, and other public sources of data.
Avoid dictionary words in ANY language
Criminals use sophisticated tools that can rapidly guess passwords that are based on words in multiple dictionaries, including words spelled backwards, common misspellings, profanity, and substitutions.
Avoid using only one password for all your accounts If your password is compromised on any one of the computers or online systems that use it, you should consider all of your other information protected by that password compromised as well. This post may be a little late.
If you need password recovery like windows password recovery, windows Password Reset 7.0 also supports windows 7 password reset.you should refer to How to Recover and Reset Password in windows 7/Vista/XP/2003/2K/NT for Free. .
Computers & Internet Logo
how to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    How do I enable wpa encryption? I have an
    To set up the correct security protocols for your router:
    1 Click Control Panel > Device Security.
    2 In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive
    characters as well as numbers. It cannot be longer than 64 bytes.
    3 In the Login Password field, enter your Login Password. Create a password that
    contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
    4 Re-enter your Password.
    5 Click Apply.
    6 Once the settings have been accepted, click Restart and log back into the
    Configuration Utility using your new User ID and Password.
    7 Select Wireless > Basic.
    8 Change the SSID to a user-friendly name and click Apply.
    9 Navigate to Wireless > Security.
    10 Select WPA-PSK from the ESS Authentication options.
    11 Select TKIP from Encryption Status options.
    12 Click Apply and then click Restart. Your wireless security configuration is now
    complete.
    Mar 26, 2009 | Arris WR850G Router (DHWR850G)
    free agent doesnt encrypt
    I Posted a solution to this prob but i don't see it anymore. Your ext drive is Encrypting your folder. It just knows you're the one using it. If I took it and plugged it in to my computer, it would recognize my user name as t0mthab0mb and prompt me for the password. Try it. Create a different user account on your computer, then try to access the encryption folder from the new account.
    Mar 01, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
    password in files
    Well if you can save the file but are unsure how to store and keep the file on your pc and have it be safe I would recommend something called Folder Lock. I will provide you a link.
    Link: http://www.newsoftwares.net/folderlock/
    Summary:
    • On-the-fly 256-bit AES encryption (military standard) for data security.
    • Just as Lockers in physical world, different users can create their own Lockers. A single user can create multiple Lockers with different passwords as well. With Folder Lock, you can choose either to encrypt using 256-bit AES on-the-fly encryption or lock files, folders and drives anywhere on your computer. Each Locker can contain your encrypted files as well as your personal list of locked items.
    Dec 17, 2008 | Microsoft Windows XP Professional With...
    367 people viewed this tip
    David Payne
    David Payne
